Is This View Good?
Hi Guys,
I've interested in one of the unit in Tampines and viewed it myself this morning (only from outside:P).
The main door (NE) and window facing (SE) direction is what I want but I found that other block (triangle shape) in front is actually directly hit to this unit, I attached the picture here, kindly help to justify and comments. Thanks.
Cheers,
V
See the 2 blocks in front that have bamboo stick with hanging clothes, the blocks shape is kind of triangular and hitting the corridor where I stand and took the picture.
Edited by vibranze
  • Replies 42
  • Views 9.3k
this pic taken while standing directly outside main door?
dont see anything wrong leh
Have la, a little bit, triangle pointing. But dont know whether the triangles are pointing to the main door or the window.
@MaCe,
Main door is actually facing the wall, and this picture was taken while standing in front of the window.
@Nipponho,
This is what I think so even it is not hitting the main door but is it good if it is hitting the window?
:sport-smiley-018:
V
@MaCe,
:sport-smiley-018:
V
didnt see anything wrong - for sharp corners only the 4 corners of a opposite building poses "threat" - none of the opposite building's corners are facing you wat.
There is this thing called, Tian Zhan Sha, I not sure if this applies to this pic. I heard about this, something to do with triangular roof tops pointing towards your house. U look at the top, u can see the triangular roof top, very obvious. Note : I MAY BE WRONG, I BASED ON WHAT I HEARD VAGUELY
where are the triangular rooftops? :jammin:
Sorry guys, maybe you are all confused with which triangular shape I was referring to, kindly refresh the page and you will see there is 2 red circle in the picture, that was what I meant by triangular shape.
Hope this clarifies.!!
Cheers,
V
it is a rectangular roof. a triangular roof, take a look at potong pasir.
Yeah those are the ones. Sorry i don't mean triangular, but the right angle of square or oblong that is pointing, it appears triangular bec the angle is pointing towards the camera.
It's not only the roof top, i goes vertically downwards.
Cheers,
V
ok, saw those you circled. this only applies to paranoids.
dont worry. only count those at EYE level + a building's 4 corners. a single typical hdb building have countless such corners if you count in all the structural pillars, protruded utility rooms, bamboos...etc
99.9% of all hdb houses' doors/windows sure can see such things...my house i can count at least 20 over such corners although i am staying at 2nd flr.... !!
but if triangular roof, (inverter V type), then it is slanted, then not very good rite. Cos the pointed end is pointing downwards.
So even though it is above your unit, it is aiming at it right?
@MaCe,
Haha, I see, so I will take your advice for granted, just ignore it:P
@Nipponho, Raincole,
Yes, it is a rectangular roof but what I meant was the triangular corner, my bad not describe better:)
So for the vertical downwards triangular shape, is it also safe to ignore?
Cheers,
V
only the direct 45 degree is counted. meaning the sharpest end is pointing directly at you.
