Electrolux Or Brandt? - For Front Load Washer / Dryer
Which of the following is a better choice? Thanks.
Electrolux
W/M: EWF1084
Dryer: EDE606A or EDE429E
Brandt
W/M: WFH10771A
Dryer: EFE310K
Electrolux
W/M: EWF1084
Brandt
W/M: WFH10771A
Dryer: EFE310K
I'm getting the Electrolux EWF 861 & EDE 429E
Anyone used them before?
I have only use Brandt before, so can't say abt Electrolux. Brandt is pretty good, and we just got a new one recently.
Any reviews for Electrolux EWF771?
I was quoted $760 by a neighbourhood shp.
Good price?
Electrolux
W/M: EWF1084
Brandt
W/M: WFH10771A
Dryer: EFE310K
Is the price the same between these brands? I've use both brands before, I find Electrolux quality are better interm of electronic. However, I can tell you that you must look for a machine that will swtich off after washing or drying, this can safe some power consumption. I known Electrolux equipped with this feature. Brandt also ok if you want a simple and does the washing, it's still a good assistance. There a lot washer with many many features but eventually you'll be using 1 or 2 function only.
Thanks for all the advise. Not decided between Electrolux and Brandt. :unsure: In the end may go for the Brandt has it has a bigger capacity dryer.
Edited by crazycar
Good price?
That's quite a good price. Lowest quote I got for it was $750.
But EWF771 is a low end range right?
I just want some reassurance that it's good. KS...
Anyway better to pay a little more for Electrolux. LG front load (non direct drive) already costs $600.
Thanks for all the advise. Not decided between Electrolux and Brandt. !! In the end may go for the Brandt has it has a bigger capacity dryer.
5kg should be ok, unless you've a lot to dry or you need to dry Comforter, Just note that Dryer consumed a lot of electricity..just like Air-con..
