Can Solid Surface Be Cut Into This Shape?
i plan to do a L shape kitchen cabinet and solid surface but i have a recess area. i tried to draw the portion of my kitchen cabinet and sink area out. hee.. lousy drawing..hope can get some advice here?
thanks!
i am wondering if solid surface can be cut into any shape and length? something like mine?
it will be 2 piece join together to form a L shape. yr layout is similar to mine..
Agree it will be 2 piece join together. Mine too, but mine the joining area very small.
alamak now then i realise i cannot click to enlarge my pic..
do you guys mean it will be 2 different piece one which is the one with the pipe, the other is the one with the sink drawing?
hmmm dun like join lines..will there be any problem with your join lines?
so i guess the limitation of solid surface is width. too wide to be one piece for my layout.
think for solid surface there isn't really a problem with joint lines
they'll install it onto the cabinets and buff until you can't really see the joint line, let alone feel it :yamseng:
joint lines on solid surface is not very visible IF yr supplier's workmanship is good.
if one big piece, probably can't fit into elevator!
Yes its possible, my table top is L shaped like yours too...
After installing they will grind and polish the surface to get rid of any joint lines... :)
u mean the polishing wont blur off the solid surface? :) it will still be glossy rite?
