Help ...
i was installing a bamboo blind, ceiling mount ... after i drilled a hole in the ceiling and put in a wall anchor, i tried to screw a hook (those screw type) into the ceiling, think i tried too hard, the hook broken off at the neck, and hence left the screw inside the ceiling, only a very tiny piece, where it broke, can be seen
i tried to use a plier to pull out the remaining screw, but it kept slipping away as the piece left outside is too small for the plier to get a firm grab :furious:
can anyone advice me what shall i do to remove the broken screw from the ceiling? :(
If u are using the nylon plug, use thin drill bit to drill onto the plug.
thank you for the suggestion, guess i have to try it next time, as i have already given up ... i patched up the existing one, and drilled another hole nearby :D
