Keat & Jane New Home
Finally received approval letter from HDB and now can officially start tracking the progress of the renovation... :P
Type: 5I
Moving in: Mid April
Reno start: March 14th
Reno (Strategic Design, William)
Aircond (Toshiba inverter system 3 with upgraded piping and 5x servicing contract) = $3309
Sofa (Cellini Simona Module A+D): $1480
Mattress (Cellini Nightingale King Size): $698
Joven Heater (from Hupfari, 25L): $225
Rain shower x2 (From JB): $236.5 each
Master bathroom basin (from Hupfari) + tap(From JB): $131
Common bathroom Basin set (from KL): $318
W.C (From Hupfari): $190 each
Fan (3 Fanco Aroma + 1 Fanco FF 2000, both from JB): $816
2 bowl Kitchen sink set (From KL): $235
Hob & Hood (Fujioh, from Hupfari): $750
6" square Downlights (22 sets, From JB)): $442
Kicthen lights (From JB): $67
Dining table lights: $153
Movers: $268
Toilet, kitchen & other accesories (Hand spray x2, rack for kitchen cabinets, Altar table downlights): $166
Still to come
Curtain: $?
Electrician: $?
Store room rack: $?
Before Reno Pictures
Edited by shkeat
  • Replies 114
  • Views 21.6k
spam chop :dancingqueen:
only two or three weeks for the renovation?
that's really a little rush :jawdrop:
btw the previous owner looks like a hoarder :lol: :lol:
Edited by applefreak
congrats! Another Tampines lover... :)
Thanks.. :sport-smiley-004:
My ID say can make it so ok lo... :P
wow 40k something that's quite a huge sum of money! can share the quote here? :jawdrop:
Congrates on ur new home! Hehehe... Looking forward to more pictures, and here wishing you a smooth reno journey. :)
Agree!! woah~ look at their stuffs!
Thank you all... :dancingqueen:
Will post the photos of each stages as it progress on... :D Can't wait to move in as well :P
For the quote, will post tonight reno is only 32.4K. The rest is from "other stuffs" :P
Was trying to reduce to lowest possible but my friend (William from strategic) say that's the best he can help. Had survey around a few other ID and the quote is around the same (excluding the special items i requested.. tear down kitchen wall for open concept kitchen with a bar counter, rebuild the wall between masterbedroom and bedroom 3, 2 8ft wardrobe, raise the floor of my balcony after taking down the sliding door). Will be higher if added in those extra items i want..:(
Not "their". It's only 1 occupant... :sport-smiley-004:
1 occupant only? saw like got wedding pic in 1 of the room with alot of cap.
Besides the stuff lying around the house, the bedroom, living room & kitchen looks good.
What the? 1 occupant got so much junk? he garung guni? :jawdrop:
Sadly, he's on divorce case. His family moved out already. :(
All the bedrooms and study room are in parquet and good quality ones. That's why i'm keeping those. Just revarnish only. Need to tear the dining are platform though cause it's hollow at the bottom. As for kicthen cabinets. Sadly i had to tear it down also cause i'm doing a open concept kitchen and his theme (country) don't fit mine...:( else i would have keep it cause it's all solid wood cabinets.
:jawdrop: All those stuff belongs to ONE person? :jawdrop:
Wao, tat will save quite a sum of $$. Hacking and tiling is very X. :good:
Edited by Angel81
Here's the quotation i signed
Hacking & Demolition Works
1) To hack away existing wall tiles at kitchen & 2 toilets
2) To hack away existing floor tiles at kicthen & 2 toilets
3) Dismantle and dispose off existing kitchen cabinet
4) Dismantle and dispose off existing cabinets, wardrobes at bedrooms
5) Dismantle and dispose off existing w.c. suites & wash basins
6) To dismantle and dispose off existing raised platform **** hall
7) To demolish wall at master bedroom for new entrance and kicthen entrance
8) To dismantle and dispose off existing raised platform at master bedroom
9) To hack away existing flooring at balcony
10) To hack away existing flooring **** / dining hall
11) Haulage of raw materials & removal of debris
Masonry works
12) To supply & lay ceramic wall tiles (300mmx450mm) at kicthen
13) To supply & lay non-slip homogeneous tiles (300mmx600mm) at kitchen
14) To supply & lay ceramic wall tiles (300mmx450mm) at master bathroom
15) To supply & laynon-slip homogeneous tiles (300mmx300mm) at master bathroom
16) To supply & lay ceramic wall tiles (300mmx450mm) at common bathroom
17) To supply & laynon-slip homogeneous tiles (300mmx300mm) at common bathroom
18) To supply & lay waterproofing membrance at kitchen & 2 toilets
19) To construct cement mortar cabinet, fridge and washing machine base
20) To seal up wall between master bedroom and bedroom 3 using partition board
21) To supply & lay homogeneous tiles (600mmx600mm) **** / dining hall complete with skirting
22) To raise up the floor level at balcony to flush with living hall, complete with homogeneous tiles
Plumbing works / sanitary works
23) Copper piping for whole unit (hot and cold water)
24) Inlet / outlet piping for washing machine
25) Inlet / outlet piping for kitchen sink
26) Supply labour to install 2 sets of w.c. suites
27) Supply labour to install 2 sets of wash basin with level taps
28) To supply labour to instal storage tank heater
29) To supply labour to install toilet accessories
Carpentry works
30) Design & install L40ft laminate finish kitchen cabinet in laminate finishing, complete with 2 tier stainless steel dish rack, cutlery tray, 2 nos. frosted glass door with aluminium frame (internal carcass in woodgrain PVC)
31) Supply and install L22.5ft solid surface counter top
32) To design, fabricate and install built-in wardrobe in master bedroom in laminated finishing complete with aluminium frame sliding glass doors (8ft)
33) To design, fabricate and install built-in wardrobe in bedroom 2 in laminated finishing complete with wooden swing doors (8ft)
34) To design, fabricate and install altar table L3ft **** hall in laminated finishing
35) To design, fabricate and install TV console **** hall in laminated finishing L8ft
36) To design, fabricate and install full height shoe rack **** hall in laminate finishing L4ft
Misc Items / Works
37) To supply labour and material to paint whole unit, using ICI emulsion Supreme 3 in 1, maximum of up to 5 colours (include painting of pipings, doors and door frames)
38) To supply & install aluminium sliding window at existing balcony area
39) To revarnish existing parquet flooring at bedrooms
40) To touch up long strip parquet flooring at master bedroom after demolish of wall for new entrance, include laying of skirting at new wall between master bedroom and bedroom 3
41) To supply & install 10mm thk tempered glass shower screen at master and common bathroom
42) Chemical floor washing for whole unit
43) To supply and install aluminium window grill for whole unit
44) To construct L-box **** and dining hall
45) To construct L-box at master bedroom
Edited by shkeat
