Glass Sliding Door
I wanted a 10mm thick glass sliding door. However, I understand from a glass contractor that there is only 8mm thick glass sliding door. Is this true?
I am afraid that if it is too thin, it might break when someone knock into it.
Help!
not true......go check direct with the glass makers..... ;)
Help!
hihi... maybe u can contact me at 82231787 for some advice??
thx guys... Is there a standard price on this? Anyone knows the market rate?
Help!
hi,
i just renovated my hse, i use 10mm thk tempered glass for my kitchen entrance lo..
check on my blog
http://www.renotalk.com/forum/index.php?au...blogid=602&
wei
the std thickness for tempered glass doors are 10mm, if i am not wrong; this is the min.
there are those who choose 12mm for higher doors; but they are much heavier.
there are many useful threads in this forum on the various aspects of reno - i also got to know the above fm my daily reading :)
The optimal thickness is 10mm and the glass criteria must be tempered.
Its was to ensure safety for the users especially the height was built to at least 2.1m.
Cheers.
  • 4 weeks later...
ya 10 mm is good enough, I regreted it for my kitchen door using 12mm thick, old hse use 10mm much lighter & smoother. should had listen to the supplier recomendations...............
up till now, i have never heard of people using 8mm.
i use 10mm tempered for all my glass panels, sliding door, swing door. floor to ceiling. 8ft high
