Full length sliding panel
Image Temporary removed, owner not comfort with the pic taken by HP, to repost after professional photographing :P storage after the sliding panel
it helps to hide sliding glass door between kitchen and dining hall
Image Temporary removed, owner not comfort with the pic taken by HP, to repost after professional photographing :P full view from Dining Hall
Edited by Tiler Seng
Dining & Living Hall over-view
Shower Room
Master bedroom
Hi Tiler Seng
Could you provide me with the quote for the following:
1. Laying of cement screed prior to laying of homogeneous floor tiles for living/dining & storeroom
2. Laying of 600mm x 600mm homogeneous floor tiles for living & dining hall
3. Laying of 600mm x 600mm homogeneous floor tiles for store room
4. Laying of glossy homogeneous skirting for living/dining & storeroom
5. Construct main door entrance kerb
6. Construct 50mm kitchen cabinet base with tile finish
7. Construct 50mm fridge & washing machine bases with tile finish
8. Construct Shower kerb at 2 bathrooms with tile finish
9. Laying of HDF laminate flooring at all bedrooms inclusive skirting
10. Supply & install frameless tempered clear glass shower screen for both Toilets
11. Laying of concealed 2" drainage pipe for kitchen sink
12. Laying of concealed 2" drainage pipe for washing machine
13. Extension of copper piping to new kitchen sink position
14. Labour to install 2 set of instant heaters or 1 set of storage heater
15. Labour to install 1 set of Kitchen sink & tap
16. To supply & run hand spray point at master toilet and common toilet
17. Design, fabricate & install (L) 20ft kitchen cabinet
18. Custom made 10ft(L) solid surface worktop c/w 50mm backsplash & front profile
My flat is a brand new standard 4 room hdb (ard 92 sqm)
I can be reached at email: heman5864@gmail.com
Hi tiler
I want to replace the cuurent vinyl tiles to new ones for my 2 standard size rooms. Mine is the 3I room. not sure how many sq feet.
Could rough quote the price.
And painting for the whole house.
Hi Ronald / Seng,
Sent you a PM earlier, hope to be able to get your quotes soon as i'm expecting to start reno works in early-mid sep.
Can you pls send me your email soon so that i can send you my floor plan and requirements.
My email is leeymei@hotmail.com. Thks!
Hi Ronald / Seng,
Have PM you ;)
Hello
Sent an email for quotation on 1st Aug 2011.
Appreciate if get provide me quotation asap as I intend to start reno first or second week of Sept.
what is your email address?
