sunrisec
Preliminary Reno Budgeting
Hello fellow forummers, im a newbie and just got my resale 4rm (105 M2)flat which i intend to do some reno to make my house look clean and simple....intend to do some careful budgeting as my pockets are not deep. would appreciate if anybody can give a rough guide on how much it would cost for the below activities..:
Hack the floor of living room and 3 bed rooms
Hack floor and walls of kitchen
Hack floor and walls of 2 toilets and remove basins and toilet bowl
Lay 60 X 60 homo tiles for living room and 3 bedrooms floor
Lay ceramic tiles for kitchen, install basic kitchen sink and stove..
Lay rough tiles for 2 toilet and install (new showerhead, basins and toilet bowl) X 2
Make the wall smooth and painting of whole house.
Simple lightings installations of whole house..lights decided to get from IKEA
would really sincerely appreciate some indication of how much these activities cost under a contractor......thanks alot..
Hope my quotation helps. Mine is 4rm 108sm. Just to give you a rough estimate.
DEMOLITION WORKS
To supply labour to hack whole house wall & floor tiles incl skirting
To supply labour to hack existing sink & stove support
To supply labour to dismantle bathroom & kitchen fittings
To supply labour to dismantle kitchen cabinet $ 3,050.00
WET WORKS
To supply & lay 600mm x 600mm homogeneous floor tiles c/w skirting to $ 5,650.00
living, dining, store & 3 bedrooms (tiles budget up to $2.70 psf)
To supply & lay 300mm x 300mm homogeneous floor tiles to kitchen & $ 1,950.00
2 bathrooms (tiles budget up to $2.40 psf)
To supply & lay 300mm x 600mm homogeneous wall tiles to 2 bathrooms $ 2,350.00
(tiles budget up to $2.50 psf)
DEMOLITION WORKS
WET WORKS
hi MTlot,
This is useful information, i guess i have to budget in total about 15k+- for the above items...think should be reasonable.
Thanks
hi sunrisec,
without u aknowledge, i already pmed u my contractor nos. hope u dun mind.
hi MTlot,
Thanks
Sure no problem, but have to take into consideration how much things to hack off and it's better to bring your contractor to have a look at your place 1st before asking him to quote you. My quote for hacking quite high due to ex-owner left back a lot of wall cabinets and i want to remove every single item. :D
DEMOLITION WORKS
WET WORKS
hi,
does this pricing including Debris removal/haulage, sand & waterproofing?
hi,
I suppose it's included of debris removal/ haulage... never stated in my quotation. Waterproofing works as below:
To supply & lay water proof membrane to kichen & 2 bathrooms $570.00
Cheers :yamseng:
ok...taken note of this..my house is quite bare..in fact no fixed cabinets or items...maybe more costs on lightings and electrical wirings reworks
Then you need not worry so much on the cost of hacking.. in fact you can ask for reduced $$ if you feel they quote you on the High side. :yamseng:
Cheers :yamseng:
think btr make it clear before u sign anything...
in case of hidden cost.
$3000 including waterproofing, haulage and clearing of debris.
Labour to lay tiles - $3900, owner to provide tiles. Tiles should cost ard $3000-$4000.
Should be ard $2000.
It depend on how much lighting, wiring u doing...should be ard $1000
My comments as of the above in blue.
Edited by jaskel
Making the wall smooth means plastering or?
Any idea how much it will cost for a 5I flat? 121 sq m.
Thanks!
