Is This Price Alright
Hi Everyone just got an quotation for my house just wonder is $22000 a reasonable price for the renovation ....please help thanks
Design, fabricate & install Est 20fts of laminate kitchen cabinet using solid ply wood
Supply & install 1 nos of Stainless Steel Sink inclusive of tap (Single / Double)
Supply & install 1 nos of Stainless Steel Disk Rack
Rerunning of Copper piping for sink & washing machine point
Rerunning of Copper piping for kitchen & 2 toilets
Hack existing floor tiles of kitchen & 2 toilets
Hack existing wall tiles of kitchen & 2 toilets
Supply & lay floor tiles for kitchen & 2 toilets
Supply & lay wall tiles for kitchen & 2 toilets
Supply & lay Prepacked cement & waterproofing for kitchen & 2 toilets
Recasing of existing wiring in kitchen & 2 toilets (include light installation)
Acid washing for kitchen & 2 toilets
Construct cabinet base, fridge base & washing machine base
Supply & replace stainless steel refuse chute
Supply & install 2 sets of toilet bowl
Supply & install 2 sets of wash basin inclusive of tap (without stand)
Supply & install 1 set of Instant Heater
Supply & install 2 sets of bathroom accessories (with mirror)
Haulage Fees to haul materials to unit
Debris removal fees
ADDITIONAL DEMOLITION & WET WORKS
Hack existing wall between kitchen & living room $500.00
Erect half height wall with hollow blocks in kitchen for L shaped kitchen cabinets $150.00
WINDOWS
Measure, fabricate & install aluminium sliding window grilles at Kitchen, living &
3 bedrooms $990.00
Measure, fabricate & install aluminium casement windows for master & bedroom 2 $650.00
Measure, fabricate & install aluminium sliding window at bedroom 3 (3 way track) $350.00
MISC
Measure & install Laminate flooring for Living & 3 bedrooms (with skirting) $3,000.00
Measure, fabricate & install Est 14fts Solid Top Surface for kitchen work top $1,050.00
Measure, fabricate & install 01 nos wrought iron gate $520
Supply & install 03 nos veener doors for 3 bedrooms (semi hollow) $930.00
total $22,000.00
Debris removal fees
WINDOWS
3 bedrooms $990.00
MISC
total $22,000.00
Bro,
pls post your floor plan.
With that will be much easy for the bro here to comment.
This item can ask them to waive off should be able too. And then to save some cost if budget a bit tight change the doors to classic should be able to cut 40% off the price. Just 2cents opinion.
Bro,
Hi How do I go about attaching the floor plan...cheers
Hi Tyseng,
Yours is consider very low, compare to the quote I got for my new home. :dunno:
Will be calling Hoe Bee, Ah Soon and another contractor recommended by a fellow forumer.
Any comment or other recommendation?
Attached below is the quotation I got from a "Old friend" contractor that my family had been using since I'm a kid. 8|
There is a Chinese saying "Own people easier to slaughter" :curse:
quotation for my 4rms flat
Thanks in advance
Edited by user101
Hi Tyseng,
Thanks in advance
Hi YOur floor plan is the same as mine...
My reno spec is about the same as your.
The only dif is the flooring, I'm doing homogeneous tile thought-out.
$22k is consider reasonable.
How many quote have you got so far?
Mine also super similar to you guys
Hi Tyseng,
Thanks in advance
You got the same floor plan as my current home @ Hougang but I will be getting my new home at Pinncal @ duxtron in Dec
currently looking for ID and quot too
What some research and home-works can do?
My 1st quote from a "Old family friend" = $57,000.00
2nd quote from one of the popular contractor in this forum = $47,000.00
3rd quote from a neighborhood contractor (Non-renoTalk) = $37,000.00
4th quote from a contractor that a friend recommended (Non-renoTalk) = $37,000.00
All the above spec given for the quote are about 90% similar.
I wonder! How the h*ll could the quotation be $20,000.00 difference? :dunno:
Material, brand, design can be the cause of it.
most likely will be the material n design ba. ID and contractor will also hv diff pricing.
In order to be fair to the contractor, u got to compare against apple to apple.
:) but anyway no harm to get more quote, if u interested can try up with my contractor.
Your family needs some new friends! ;)
I may be friendly but I'm no carrot! :D
Debris removal fees
WINDOWS
3 bedrooms $990.00
MISC
total $22,000.00
I've just replied to another forumer...this is my quote, hopefully it can help u to compare.
I got 3 quotes too.
I did not do as much as u, my quote (resale condo, 1238 sqf), condo and HDB have got different height.
HDB 2.4m, condo 2.9m
1) Indoor and outdoor paint for entire house
2) Chemical washing for entire place
3) Polish exisitng granite flooring
4) Revarnish parquet flooring + finishes with lacquer
5) Paint all doors
6) Construct base for fridge and washing machine
7) Shoe shelves
8) Custom make 14ft (L) TV console with wall finishing + shelving + wallpaper
9) False ceiling + Light Box + Cove lighting for living and dining area
10) 2 sets of custom made wardrobe 6ft (L) with sliding door
11) 6ft (L) study table + drawers + 3 suspended book cabinet
12) 2 sets of 6ft (L) granite top for bay window
13) Wardrobe 8.5ft (L) with sliding door
14) Custom made king size suspended bed with side tables + bed head
15) 10ft (L) granite top for bay window
16) Light box + cove lighting for master bedroom
17) Wall feature mirror at dining area
18) Change entire suite of existing switch cover
19) Install another 4 electrical point
20) Changing of toilet bowl
Plus hacking of existing cupboards, etc...well, actually my ID added in some extra stuff for us too. ( i did not type in everything here)
He has quite *****.
Total cost: Close to $15, 000
