Revamp Of A 40yo 3rm Pigeonhole...
Today ceiling works started…
Workers laser aligning false ceiling line…
Edited by neubie
  • Replies 451
  • Views 203.3k
  • Up till now, the sequence is like this: - Demo (9 Sept, 13 Sept) - Clearing (14 Sept) - Upload materials (14 Sept) - Tiling bath/WC floor, kitchen wall, install door frame (15 Sept) - Tiling liv
  • Try the shophouses at 277 Kranji Way... plenty of hardware shops selling....make sure you check with your carpenter what is the depth of the drawers and get accordingly... I'm using the 560H (tandem
Dining area almost done & gas/AC/aircon drainage pipes boxed up
Living area still outstanding...
MBR skeleton up...
Meanwhile, all my lights have arrived :wub::dribble: all 22 downlights taken out, inspected, cleaned and loaded with 14W genie tubes...baton lights for cove lights, UFO-shaped ecomoods pendant dining lights and decotwist for utility room
Looks similar to any other downlights, but with a ceramic E27 lamp-base for durability, as well as PLL tubes with built-in electronic ballast for flicker-free startup...
...plus shiny anodized reflector surface that would outperform any 18W PLC in terms of projected light output...
Yesterday's work
MBR
A/C FCU pelmet done
Common room
A/C FCU pelmet done
Living room done, with ceilings touched up
coming next, stopping compound to be applied to seal up the gaps...
Edited by neubie
I'm also getting the Philips Downlight. Can tell me where do you get it from ?
Rgds
WOW, (JAW DROPPED) SUPER NICE .. THE DOWNLIGHTS FROM PHILIPS WITH ELECTRONIC BALLAST WOULD HAVE COST AN ARM & A LEG!! SWEE , VERY SWEE.....
THE UFO SHAPED LIGHTS FOR DINING ROOM USE........ HOW DOES IT LOOK LIKE? NEVER SEEN THEM BEFORE , NOT EVEN IN THE PHILIPS SHOWROOM
have, try popping down to lighting.com.sg @ Jln Berseh or click here or as shown below:
Rgds
Here. But this is a hot item... i waited for almost 3 weeks before they call me to take delivery... alternatively, u can try block 637 Veerasamy Road there. They also sell philips lightings at similar pricing as lightings.
Ceiling works completed today :dancingqueen:
MBR
Common room
Tmr will be a rest-day before painting on Friday...
The model you got is Philips FBG304 (1x14w) right. I'm interested in getting the Philips FBG305 (2x14w). Did you did any comparision among this two ? If have, how is the brightness ?
ThanKs. :rolleyes:
ThanKs. :rolleyes:
Of all things equal, the 2 x 14w shd be 2x brighter than 1 x 14w. Comparing with normal 2 x 18w, the 2 x 14w is more brighter. Ask for a demo and let ur eyes judge. The downside is:
- it cost more ($45)
- can only fit one dimmable easyscene bulb n no more space for the normal 14w tube
Irrespective of which model u choose, removal of blown tubes is done by unscrewing the thumb nuts n remove the glass panel. Other brands may require prising open the glass frame (possibly dirtying the surrounding area of the ceiling).
The size is slightly larger to accommodate twin tubes. So have to see does it look right in proportion to the false ceiling or L-box.
Edited by neubie
Wow, whats was the total damage of your philips lighting, very cool.
almost a grand :(
I like your Lourve+ Slide windows at yr living room!!
I was looking for something like that!
Can please share the supplier/cost ?? :D :D
Cost $550 per piece. Supplied by my main con's supplier:
Xiang Jin Iron & Aluminum Works P/L
Tel: 6755 7677
HP: 9238 1010 Yong
HDB licence: HB-01-2404A
