Our Home @ Eunos
Yes, YY told me that its possible changing the WC to 'P'-trap
ohh if the ID says ok then ok ba... :)
i thought i read somewhere that HDB is very sticky on the toilet bowl thingy...
how wide is the toilet? able to squeese in shower screen, toilet bowl and sink...? U got the dimensions for each section.?
my toilet (3NG) is sooo small that i had to sacrifice one toilet bowl in order to have a shower screen...
  • Replies 50
  • Views 21.1k
based on my reno experience, when ur ID tell u can change from S to P trap, that only answer the question if you can do a concealed cistern.
At the end of the day your waste trap will still be in it's original position, just a matter of how your ID is going to channel the waste from the new position to the original waste trap hole. Not impossible but you will not like the amount of space you will be wasting.
Don't waste your time and energy pondering which design is better until you clarify with your ID.
dexufto: Hihi:)Thankss! I will upload my quotation later , its with my husband now
We havent confirm our master room toilet, which do you all think is better??
A
B
Nice 3-D design!
I guess B is better, it will save some problems in the future as it does not need to change the position of the WC, that is my thinking....
Edited by yeo99
I know what you mean gimz...
Janelle, has a relatively spacious toliet,
with about 2000 to play, she can afford a shower (700), basin (600) wc (500)
provided that she's reconfiguring wc to P-trap.
Let her check with her ID as what vratenza suggests, is it worth the reconfiguration.
Janelle, do you have any pic of your mbr toliet?
wonder if there's any pipes around the area?
Hi guys, thanks for the recommendations:) i've chosen the design B for my master bathroom.... will still shift the WC bowl abit using "offset" to make it closer to the wall and allow a better position for the vanity.
qimz63251073: my designer say tat the onsite measurement will be 700mm for shower area, do a 600mm vanity and 600mm WC space
vratenza: i've clarify the conceal cistern, they will need to construct a low wall for the conceal cistern and a full pcs mirror across
dexufto: i dont have clear pics of the master bathroom now. will try to take a photo soon. but there's a pipe coming down from ceiling all the way to floor near the toilet window
dexufto, macy84 : Heres my quote..I went to 6 different ID doing the same items(i have alot to do, major overhaul) and this is the cheapest i gotten
A MASTER BATHROOM
1 Hack and cart away existing wall tiles $ 240.00
2 Hack and cart away existing floor tiles $ 140.00
3 Hack off existing bathroom accessories $ 80.00
4 Supply and lay water-proofing membrane $ 150.00
5 Supply and lay floor tiles (Tile cost $2.50 per sqft) $ 300.00
6 Supply and lay wall tiles (Tile cost $2.50 per sqft) $ 1,200.00
7 Supply and construct 1 nos. of shower kerb $ 120.00
8 Supply and install 1 nos. wall to wall (straight) Shower Screen (door & fixed panel) $ 380.00
9 width 1500mm, Height 1830mm
10 Supply and install 1 nos. two way tap $ 60.00
11 Supply and install 1 nos. WC bowl $ 320.00
12 Supply and install 1 no of ceramic basin with tap $ 260.00
13 Supply and install 1 nos. tempered glass 3x7 ft sliding glass door w full sandblast $ 700.00
14 Alter WC bowl outlet using P-trap $ 180.00
15 To construct low wall using hollow block to conceal P-trap $ 350.00
B COMMON BATHROOM
16 Hack and cart away existing wall tiles $ 240.00
17 Hack and cart away existing floor tiles $ 140.00
18 Hack off existing bathroom accessories $ 80.00
19 Supply and lay waterproof membrane $ 150.00
20 Supply and lay floor tiles (Tile cost $2.50 per sqft) $ 300.00
21 Supply and lay wall tiles (Tile cost $2.50 per sqft) $ 1,200.00
22 Supply and install 1 nos. two way tap $ 60.00
23 Supply and install 1 nos. WC bowl $ 320.00
24 Supply and install 1 no of ceramic basin with tap $ 260.00
25 Supply and install 1 nos. aluminium PD door $ 300.00
C KITCHEN
26 Hack and cart away existing wall tiles $ 580.00
27 Hack and cart away existing floor tiles $ 250.00
28 Dismantle and dispose existing kitchen cabinet $ 250.00
29 Supply and lay waterproof membrane $ 150.00
30 Supply and lay floor tiles (Tile cost $2.50 per sqft) $ 900.00
31 Supply and lay wall tiles ard window area and rubbish chute wall $ 1,650.00
32 To plaster and make good kitchen wall (area with no wall tiles) $ 450.00
33 Supply and install 13ft coloured glass backing on between bottom and top $ 350.00
kitchen cabinet
34 Supply materials and construct 50mm cabinet base with side tiles $ 150.00
35 Supply materials and construct 50mm fridge and washing machine base with $ 120.00
full tiles
36 Design, fabricate and install top and bottom kitchen cabinet with laminate and $ 2,730.00
ABS trimming (29 ft):
- Stainless steel dishdrainer
- Cutlery tray
- Hinges and drawers
37 Supply and install 13 ft solid surface work top for kitchen cabinet $ 780.00
38 To construct U box using gypsum board for proposed sliding door $ 280.00
39 Supply and install 10mm fixed tempered glass panel (1250mm) $ 450.00
40 Supply and install 3 x 8 ft sliding glass door with top- hung at kitchen entrance $ 650.00
41 Connect kitchen sink and washing machine inlet/outlet $ 250.00
42 Supply and replace 1 nos. rubbish chute $ 250.00
D LIVING ROOM
43 Hack and cart away existing floor tiles and skirting $ 650.00
44 Demolish existing L shaped wall, door and door frame b/w living and bedroom 2 $ 550.00
45 Supply and lay 600 x 600 homogenous polished floor tiles completed with skirting $ 2,268.00
(Tile cost $3 per sqft)
46 To construct partition wall using gypsum board (3 x 8.5 ft) between study $ 300.00
and living room
47 To construct partition wall using gysum board (500mm x 2500mm) between study $ 150.00
and living room
48 Supply labour and material to make good damaged area $ 350.00
E MASTER BEDROOM
49 Hack existing floor skirting $ 250.00
50 Supply labour and material to make good damaged area $ 250.00
51 Supply and overlay laminate floorboards completed with skirting at Study and $ 1,120.00
Master Bedroom area
52 Construct 2 x partition wall (600mm x 2500mm) with gysum board for proposed $ 350.00
Wardrobe
53 Supply and install 9 ft fixed tempered glass panel and 1 nos. 3 x 7 ft Swing glass $ 1,450.00
door
54 To construct a U-box for top-hung track of glass door & panel $ 300.00
F CELLING WORKS
55 Supply and install L-box with cove light at TV area $ 950.00
56 Supply and install false celling at remaining living room area $ 1,050.00
57 Supply and install false celling at Master bedroom + study $ 1,250.00
58 Supply and run 20 nos. of lighting points $ 700.00
G WINDOW WORKS
59 Supply and install aluminium sliding / casment windows (N.A / B.A) with normal $ 2,350.00
glass panel
60 Supply and install aluminium window grills (N.A/B.A) $ 950.00
61 Supply and install 2 sets of adjustable toilet louvers with wire glass $ 440.00
62 Seal up small window using gypsum board beside main entrance $ 250.00
H MISCELLANEOUS WORKS
63 Re-run with s/s piping for kitchen and 2nos. Bathrooms $ 650.00
64 Painting for whole house using ICI or nippon paint $ 850.00
65 Chemical wash for whole house FOC
66 Haulage, debris removal and floor protection with corrugated paper $ 300.00
I CARPENTRY WORKS
67 Design, fabricate and install 2 ft vanity cabinet with laminates and ABS trimming $ 320.00
for master bathroom
68 Supply and install 2 ft solid surface top for vanity cabinet for master bathroom $ 200.00
69 Design, fabricate and install 3 ft full height shoe cabinet w laminates (2 doors with $ 660.00
mirror finish)
70 Design, fabricate and install 5 ft TV feature wall w laminates $ 700.00
71 Design, fabricate and install 8 ft TV console with laminates $ 1,120.00
72 Design, fabricate and install 11 ft pole system wardrobe with sliding doors $ 3,070.00
(2 sliding doors with mirror finish)
73 Design, fabricate and install 7 ft bookshelf with doors & laminates $ 1,400.00
74 Design, fabricate and install 1 nos. of headboard L 6ft x H 3 ft with laminates $ 400.00
75 Design, fabricate and install 1 nos. of King size wooden bed frame with storage $ 950.00
76 Design, fabricate and install 2 nos of 2ft bedside tables with cabinet with laminates $ 450.00
TOTAL AMOUNT FOR CONTRACT $ 44,768.00
Less Discount: $ (1,768.00)
TOTAL AMOUNT FOR CONTRACT AFTER DISCOUNT $ 43,000.00
Edited by Janelle
that day my id called me after they done the hacking and say tat there's a stiffener (refer to photo). it is not reflected in the floorplan and will require PE endorsement before they can demolish it...
any comments?
extensive renovation! can't wait to see the final product. would your handover date be before or after CNY?
i can't help thinking that 11 feet pole system wardrobe + sliding doors are a steal at $3000! i'm doing a pole system sans the sliding door and it's already costing me $180/ft.
more pictures as and when you can get them up please!
Hi Janelle... Saw ur 3D and the actual tiles design. Looks cool!!
Ran thru ur quote.. Wow.. U really found a good bargain!! Mine was a arm flat too.. Total Reno cost was abt $38k with only kitchen cab.. Yours really a steal.. Hope everything will turn out to be wat u want.. Cheers! Do post more photo when there is...
nbdylovesyou and macabre_g: Thanks! sure will update again soon:)
  • 4 weeks later...
Hi all, Happy Lunar New Year!=)
Was away for business trip and then busy with CNY, finally have time to post the updates..
Will post update again on Monday:)
nice :paint:
everything coming along well
Edited by Dante
love your difference tile concept very nice , too bad u didnt get the wc that look like what your designer draw will look stunning
Hihi, didnt get because it cost us 1k includes WC, conceal cistern and a designer faceplate flush button :(
I am sourcing for a LED tv, anyone have good lobang??
Any good source for curtain??
