Our Home @ Eunos
Hi Janelle, am new to this forum, saw the red colour thingy between the top and bottom kitchen cabinet,looks great! izzit wall paper? will get damaged if doing heavy cooking? :dancingqueen:
Hi Haya, there's alot of colour for you to choose from toooo..... rem dun use wallpaper at ur kitchen area.. it might result in a great BBQ session..
  • Replies 50
  • Views 21.1k
Hi guys, thanks for the recommendations:) i've chosen the design B for my master bathroom.... will still shift the WC bowl abit using "offset" to make it closer to the wall and allow a better position for the vanity.
qimz63251073: my designer say tat the onsite measurement will be 700mm for shower area, do a 600mm vanity and 600mm WC space
vratenza: i've clarify the conceal cistern, they will need to construct a low wall for the conceal cistern and a full pcs mirror across
dexufto: i dont have clear pics of the master bathroom now. will try to take a photo soon. but there's a pipe coming down from ceiling all the way to floor near the toilet window
dexufto, macy84 : Heres my quote..I went to 6 different ID doing the same items(i have alot to do, major overhaul) and this is the cheapest i gotten
A MASTER BATHROOM
1 Hack and cart away existing wall tiles $ 240.00
2 Hack and cart away existing floor tiles $ 140.00
3 Hack off existing bathroom accessories $ 80.00
4 Supply and lay water-proofing membrane $ 150.00
5 Supply and lay floor tiles (Tile cost $2.50 per sqft) $ 300.00
6 Supply and lay wall tiles (Tile cost $2.50 per sqft) $ 1,200.00
7 Supply and construct 1 nos. of shower kerb $ 120.00
8 Supply and install 1 nos. wall to wall (straight) Shower Screen (door & fixed panel) $ 380.00
9 width 1500mm, Height 1830mm
10 Supply and install 1 nos. two way tap $ 60.00
11 Supply and install 1 nos. WC bowl $ 320.00
12 Supply and install 1 no of ceramic basin with tap $ 260.00
13 Supply and install 1 nos. tempered glass 3x7 ft sliding glass door w full sandblast $ 700.00
14 Alter WC bowl outlet using P-trap $ 180.00
15 To construct low wall using hollow block to conceal P-trap $ 350.00
B COMMON BATHROOM
16 Hack and cart away existing wall tiles $ 240.00
17 Hack and cart away existing floor tiles $ 140.00
18 Hack off existing bathroom accessories $ 80.00
19 Supply and lay waterproof membrane $ 150.00
20 Supply and lay floor tiles (Tile cost $2.50 per sqft) $ 300.00
21 Supply and lay wall tiles (Tile cost $2.50 per sqft) $ 1,200.00
22 Supply and install 1 nos. two way tap $ 60.00
23 Supply and install 1 nos. WC bowl $ 320.00
24 Supply and install 1 no of ceramic basin with tap $ 260.00
25 Supply and install 1 nos. aluminium PD door $ 300.00
C KITCHEN
26 Hack and cart away existing wall tiles $ 580.00
27 Hack and cart away existing floor tiles $ 250.00
28 Dismantle and dispose existing kitchen cabinet $ 250.00
29 Supply and lay waterproof membrane $ 150.00
30 Supply and lay floor tiles (Tile cost $2.50 per sqft) $ 900.00
31 Supply and lay wall tiles ard window area and rubbish chute wall $ 1,650.00
32 To plaster and make good kitchen wall (area with no wall tiles) $ 450.00
33 Supply and install 13ft coloured glass backing on between bottom and top $ 350.00
kitchen cabinet
34 Supply materials and construct 50mm cabinet base with side tiles $ 150.00
35 Supply materials and construct 50mm fridge and washing machine base with $ 120.00
full tiles
36 Design, fabricate and install top and bottom kitchen cabinet with laminate and $ 2,730.00
ABS trimming (29 ft):
- Stainless steel dishdrainer
- Cutlery tray
- Hinges and drawers
37 Supply and install 13 ft solid surface work top for kitchen cabinet $ 780.00
38 To construct U box using gypsum board for proposed sliding door $ 280.00
39 Supply and install 10mm fixed tempered glass panel (1250mm) $ 450.00
40 Supply and install 3 x 8 ft sliding glass door with top- hung at kitchen entrance $ 650.00
41 Connect kitchen sink and washing machine inlet/outlet $ 250.00
42 Supply and replace 1 nos. rubbish chute $ 250.00
D LIVING ROOM
43 Hack and cart away existing floor tiles and skirting $ 650.00
44 Demolish existing L shaped wall, door and door frame b/w living and bedroom 2 $ 550.00
45 Supply and lay 600 x 600 homogenous polished floor tiles completed with skirting $ 2,268.00
(Tile cost $3 per sqft)
46 To construct partition wall using gypsum board (3 x 8.5 ft) between study $ 300.00
and living room
47 To construct partition wall using gysum board (500mm x 2500mm) between study $ 150.00
and living room
48 Supply labour and material to make good damaged area $ 350.00
E MASTER BEDROOM
49 Hack existing floor skirting $ 250.00
50 Supply labour and material to make good damaged area $ 250.00
51 Supply and overlay laminate floorboards completed with skirting at Study and $ 1,120.00
Master Bedroom area
52 Construct 2 x partition wall (600mm x 2500mm) with gysum board for proposed $ 350.00
Wardrobe
53 Supply and install 9 ft fixed tempered glass panel and 1 nos. 3 x 7 ft Swing glass $ 1,450.00
door
54 To construct a U-box for top-hung track of glass door & panel $ 300.00
F CELLING WORKS
55 Supply and install L-box with cove light at TV area $ 950.00
56 Supply and install false celling at remaining living room area $ 1,050.00
57 Supply and install false celling at Master bedroom + study $ 1,250.00
58 Supply and run 20 nos. of lighting points $ 700.00
G WINDOW WORKS
59 Supply and install aluminium sliding / casment windows (N.A / B.A) with normal $ 2,350.00
glass panel
60 Supply and install aluminium window grills (N.A/B.A) $ 950.00
61 Supply and install 2 sets of adjustable toilet louvers with wire glass $ 440.00
62 Seal up small window using gypsum board beside main entrance $ 250.00
H MISCELLANEOUS WORKS
63 Re-run with s/s piping for kitchen and 2nos. Bathrooms $ 650.00
64 Painting for whole house using ICI or nippon paint $ 850.00
65 Chemical wash for whole house FOC
66 Haulage, debris removal and floor protection with corrugated paper $ 300.00
I CARPENTRY WORKS
67 Design, fabricate and install 2 ft vanity cabinet with laminates and ABS trimming $ 320.00
for master bathroom
68 Supply and install 2 ft solid surface top for vanity cabinet for master bathroom $ 200.00
69 Design, fabricate and install 3 ft full height shoe cabinet w laminates (2 doors with $ 660.00
mirror finish)
70 Design, fabricate and install 5 ft TV feature wall w laminates $ 700.00
71 Design, fabricate and install 8 ft TV console with laminates $ 1,120.00
72 Design, fabricate and install 11 ft pole system wardrobe with sliding doors $ 3,070.00
(2 sliding doors with mirror finish)
73 Design, fabricate and install 7 ft bookshelf with doors & laminates $ 1,400.00
74 Design, fabricate and install 1 nos. of headboard L 6ft x H 3 ft with laminates $ 400.00
75 Design, fabricate and install 1 nos. of King size wooden bed frame with storage $ 950.00
76 Design, fabricate and install 2 nos of 2ft bedside tables with cabinet with laminates $ 450.00
TOTAL AMOUNT FOR CONTRACT $ 44,768.00
Less Discount: $ (1,768.00)
TOTAL AMOUNT FOR CONTRACT AFTER DISCOUNT $ 43,000.00
so i guess its normal to spend 40k on reno for a 3room nwadays... OMG.. its so expensive to renovate house.... gd luck gal..
  • 1 year later...
Can PM me the ID contact?
Thanks!
hi Janelle, your place seems so huge! how many sqm?
i like the way your wardrobe is done in your masterbed room! anymore pics to share? <img src="http://www.renotalk.com/forum/public/style_emoticons/<#EMO_DIR#>/smile.gif" style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />
i'm having a headache with my masterbed room layout now. seems too small to fit in a wardrobe and king size bed.
oh, and the sink is gorgeous too!
can you share with me the contact of your ID pls? thanks!
WOW, that's a beautiful makeover of your home.
After months of the renovation journey, I'm sure you are pleased with the completed works.
Congrats for moving in Janelle.
bblifeiz, not entirely true.
A 3-room basic overhual would cost between $28-$35k.
(additional stuffs like feature walls, made-to-meaure cabinets/ Wardrobe (you can buy off the shelf), false ceiling
can contribute quite an amt to your bill)
The rest depends on quality of the products that your ID/ contractor that is giving.
Tiles, laminates, worktop and accessories (sockets, dampers, pipes)
Wow :dribble:
Nicely done up :yamseng:
