lazybum9
Our 1st Home...
We are thinking of changing the gas stove to induction hob which is smaller size than current gas stove...hence we got to change away the new solid top...i was wondering what happens next time if the induction hob is spoilt beyond repair and would have to change new...do i have to change the solid top again or the subsequent model of my induction hob will remain same dimensions...
As I know, most induction are same size, depending on how many rings. For hdb, I think only can use 2 rings so its either top bottom or side by side. Not a problem, I think.
i think if you wanna change in future, you just have to find a hob with dimension that can fit into the existing "hole" in your solid top.
may limit the choice of model but at least you dun need to change the whole solid top :lol:
why wanna change the hob leh?
I like induction hob too but I'm not prepared to convert gas stove to induction cos I still like to use Chinese wok for stir fry... So I will still install gas stove and am considering of buying a portable Taiyo induction cooker to test water...
you can come to my home to test water hahahaha :lol: i'm using the Taiyo induction cooker ;)
i'm using wok also, it looks just like chinese wok but the bottom has a small part that is flattened so that the wok can stand on the induction hob.
i've seen induction hob that has a depression so a round-bottom Chinese wok can sit in it... :)
There is also a flat bottom wok for induction hobs too. I happen to have one for my vitroceramic hob actually.
i guess my wok should be similar type as yours... though mine is only a cheapo $8.5 one from ikea :lol:
induction or gas or vitroceramic, i think all are the same if you know how to adjust the way you cook to have the same type of "wok hei". or maybe the type of wok you buy? they say cast iron will have that kind of taste....
wifey prefers to use induction so deciding to change...
Ikea has? I didn't see this. Mine is the Supre brand, think it belongs to the 20++ cost since it was my hubby who bought it.
anyone bought sofa from massimmo??? been looking around, felt that this sofa is the most comfy but the price quite steep...4k for 3-seater + ottoman...alternatively thinking of customizing at lush or santuary dian...but not confident that they can make to the same comfort level...
4k too steep lah but if can afford then ok lah. If u spend more on sofa, then less elsewhere lah.
Did u try lorenzo? Their sofa quite comfortable too, not so ex also.
