aniki 0 Report post Posted January 22, 2013 laying cable into bomb shelter, anyone tried that before? allowed?want to lay cat5 cables into bomb-shelter then use patch panel in the shelter, maybe can put 1 network switch in it? Share this post Link to post Share on other sites
Lauer 15 Report post Posted January 22, 2013 laying cable into bomb shelter, anyone tried that before? allowed?want to lay cat5 cables into bomb-shelter then use patch panel in the shelter, maybe can put 1 network switch in it?Even if you could find the way to run the cable, I doubt that the wireless could penetrate the shelter's thicker wall & door.No wireless?Cheers! Share this post Link to post Share on other sites
aniki 0 Report post Posted January 22, 2013 (edited) Even if you could find the way to run the cable, I doubt that the wireless could penetrate the shelter's thicker wall & door.No wireless?Cheers!Well, i am talking about all room each 2 or more x rj45 back to bomb-shelter(fyi you can fit 4 in a face plate), ain't you smart to place your router in the shelter instead of putting it in the living room? the bombshelter will host a gigabit switch,patch panels and a low power nasif I only got 4 points in the house, might as well use power line adaptercheers , nice thinking Edited January 22, 2013 by aniki Share this post Link to post Share on other sites
yoongf 11 Report post Posted January 22, 2013 HS is built to be airtight. Any works that will cause airtightness to fail is not allowed.Why dun just wire through the vent sleeve opening? Share this post Link to post Share on other sites
aniki 0 Report post Posted January 23, 2013 HS is built to be airtight. Any works that will cause airtightness to fail is not allowed.Why dun just wire through the vent sleeve opening?that will be abit ugly, thinking of any alternative that I can actually wire in Share this post Link to post Share on other sites
bepgof 20 Report post Posted January 28, 2013 that will be abit ugly, thinking of any alternative that I can actually wire inWall thick signal no good, vent sleeve ugly, go underground lor. Share this post Link to post Share on other sites
