3 Room Resale Ng Reno Cost
Hi guys,
Any comments on the quote? Reasonable? It was from an ID. Surprisingly, cheaper than afew direct main con.
This is based on revamping the whole house. It hasnt been maintained since the 1st owner. So everything needs to change.
Total Cost $48,164
DEMOLITION/DISMANTLE WORK
To supply labour and tools:-
to hack existing Living hall floor tiles and skirting
to hack Kitchen floor and wall tiles
to hack W.C/Bath wall and floor tiles
to hack 2 Bedroom Parquet Flooring
to hack and remove door and frame to bedrooms
to hack and remove all window to entire house
to hack of Kitchen wall for new entry
to hack of Store room and Bedroom 2 wall
to hack of wall between WC and Bath
Sub total of item 1: $3,000
MASONARY WORK
To supply labour, material and tools:-
to apply water proofing membrane to flooring at Kitchen, WC/Bath $300
to apply water proofing to upturn to wall in WC/Bath of 300mm ht $120
KITCHEN:-
to construct 50mm ht concrete plinth to Kitchen Cabinet, $450
fridge and washing machine
to lay homogenous flooring - 600xx600mm tile @ 185sqft $1387.50
to lay 75mm ht skirting to perimeter wall $300
to screed smooth all wall with cement and leveling cement $1935
@430sqft
to make good wall at hacked area $180
Grand Total of Page 1: $7,672.50
WC/BATH:-
to lay homogenous flooring - 300xx300mm tile $450
to lay homogenous wall tiles - 300x 600mm @ 430sqft $3225
LIVING:-
to lay homogenous flooring - 600xx600mm tile(@$3.00) @ 200sqft $1500
to lay 75mm ht skirting to perimeter wall $550
MASTER BEDROOM:-
to touch up and screed smooth flooring for new lamination $782.50
flooring @313sqft
to touch up skirting area for new lamination skirting $300
to make good wall to hack area at Store and Master Br $120
to construct new brick wall to extend Store Room wall $350
for Master Br and Br 2
To supply & install timber door frames to Bedrooms $250
To supply & install PE veneer door c/w lockset & magnet $420
door stopper to 2 bedrooms
To supply & install 1 hour fire-rated door in PE Veneer $1100
c/w lockset and door magnet
1 swing panel steel gate with lockset $600
Grand Total of Page 2: $ 9,647.50
FALSE L-BOX
To supply labour & material :-
to construct L box of 300mm depth from wall to 1 sides $400
of Living Hall
to construct calcium silicate board to box up bathroom $280
pipings to Bath/WC sewage pipes
PLUMBING WORK
To supply labour & material:-
to run new stainless Steel piping from outside to house $460
to run H/C S/S pipe to Bath Shower and 2 basin areas $330
to run cold S/S pipe to WC, Sink and washing machine $140
area
To supply labour to install:-
a) Storage heater $150
b) Accessories $100
c) 2 x Basins $90
d) Shower Mixer $80
e) WC $50
Grand Total of Page 3: $ 2,080
ELECTRICAL WORK
15 x Lighting point to all area $600
15 x install light fittings to all area $150
5 x install 13amp single power point $275
9 x install 13amp double power point $585
1 x install 15amp aircon power point $150
1 x install 15amp 2 way heater to WC/BATH $170
2 x install 15heater point to Hob/Hood, Oven and Mircowave $300
1 x install SCV points $120
2 x install Tel phones $90
1 x install new DB $420
LAMINATED FLOORING
To supply & install laminated flooring to Bedrooms $1600
including skirting @ 320sqft
WINDOW AND GRILLES
To supply & install:-
powdercoated casement window with tinted glass to:-
a) Kitchen @29sqft $536.50
b) Master Bedroom @18sqft $333
Powdercoated 2way track sliding window wtinted glass to:-
a) Bedroom 2 @18sqft $306
b) Living Hall @18sqft $306
2 x Adjustable louver to WC/Bath with frosted glass $360
Grand Total of Page 4: $ 6,301.50
WINDOW AND GRILLES
powdercoated 2 way track sliding grilles to:-
a) Kitchen @29sqft $188.50
b) Master Bedroom @18sqft $117
c) Bedroom 2 @18sqft $117
d) Living Hall @18sqft $117
CARPENTRY WORK
Kitchen:-
full ht laminated cabinet for Oven configured with:- $400
a) 4 x cupboard door with motion hinges $24
b) 2 x 2 tier drawers with motion tracks $44
26ft top and bottom cabinet configurated with:- $2860
a) 13ft solid surface $845
b) 24 motion hinge for cupboard doors FOC
c) 4 tier drawers with motion tracks FOC
d) glass backing between top and bottom cabinet $450
bottom cupboard with swing door in motion hinges and $380
solid surface top at Rubbish chute area
4ft full ht cabinet in swing doors with internal adjustable $920
shelves ( Laundry side)
Grand Total of Page 5: $ 6,462.50
CARPENTRY WORK
Living Hall:-
6 ft Low laminated shoe cabinet of 1000mm ht in swing door $900
with internal adjustable flat shelves
a) 600mm w full AV cabinet with lower door in slot door $660
system @ 6ft
b) 150mm thk wall panel for TV area in selected wall paper $800
c) 1 set of pivot door with Aluminum handle $450
Master bedroom:-
7ft laminated full ht wardrobe in swing door configured with:- $1,610
a) Swing door
c) Abjustable shelves
4ft 450mm D cupboard in swing door with drawers and $920
internal adjustable shelves
Bedroom 2:-
6ft laminated full ht wardrobe in swing door configured with:- $1,380
a) Swing door
b) Aluminum hanging rod
Grand Total of Page 6: $ 6,720.00
Master Bathroom:-
1200mm L vanity in selected laminated c/w:- $1,350
a) solid surface
b) mirror
PAINTING WORK
To apply sealant coating to new screed wall and L box $1,800
Emulsion painting to all wall and ceiling using ICI/Nippon
Painting work to door all sewage piping, Main door frame
Vanished work to new door frames to Bedroom to match
new doors
BATHROOM DOORS AND SHOWER SCREEN
Master bathroom tempered glass shower screen with $1,100
swing door
Master bathroom entrance fix glass and swing door in $1,200
frosted film finishing in S/S handle
Common Bathroom frosted film swing door with S/S handle. $480
Swing door in floor spring closer in partial frosted film $700
and S/S handle to Kitchen entrance
PLASTERING WORK
To supply labour to plaster smooth all wall and ceiling in $1,800
compound mixture to entire house
Grand Total of Page 7: $ 8,430.00
HAULAGE FEE
Submission Fee to HDB $200
Loading and unloading fee for material throughout project $300
Professional cleaning to entire house before hand over $350
Grand Total of Page 8 $ 850
PRICES ARE NOT INCLUDED OF:
1) Light fitting 2) Sanitary Wares 3) Kitchen accessories
TOTAL Pages 1 - 8 : $48,164.00
Hi, I just done up my 3 room resale also:) doing almost same things as urs. The company workmanship quite good. Mine is around $46000
  • 4 weeks later...
costly ...I have my unit ..resale Ubi Avenue 1 ...89sq m renovated started Mid Mar and ended End Apr ...just cost me S$37500 ...all changed
  • 4 weeks later...
Hey, samsam and king1916, I am in search for a good id or contractor for my 5-rm hdb resale flat. Mind sharing your id/contractor contacts with me by private messages? Much appreciated.
  • 4 weeks later...
quite affordable, but I suggest not using solid surface. it absorbs water and stains and is not as heat resistant. might not look nice after awhile. if you like something modern, maybe try kompactop? it's a little more expensive around $90 per foot run but it looks very modern and is 6mm thick. but if you like something traditional, can stick to granite $100 per foot run and iquartz $110 per foot run. granite need to seal every two years, iquartz and kompactop have little to no maintenance.
haha i learnt a lot from my contractor
I did my 5rm resale abt $40k include hacking. Without changing window grills and windows. Our interior designer cum contractor is good.Responsible. Still able to contact after reno job is done. Kudos to the team!
Hi, The quoted price mainly depend on the quality of the products and material that the ID is using.
I noticed that you have have quotation for laminated flooring for your bedroom.
what is the brand or type of laminated flooring you are getting?
I am using quick-step laminated flooring for 2 and half years and it has been good, no problem or issues.
http://www.quick-step.sg/en-SG
my bedroom is using Largo and living room is Eligna.
I recommend this brand.
I did not get the laminated flooring with ID but direct with quick step dealer, so that you can negotiate some discount directly with them. and it is easy to co-ordinate with the dealer and ID.
So items like laminated flooring have different brands, quality and will affect the price too.
Hope this info helps.
Hi nur, can share yr id pls.
One id recently quotated be 44.7k for 4-R resale. Doing everything, except 2 toilets.
I just did up my 3 rm resale flat 68sqm, without hacking living room and bedroom (doing laminated flooring) about 24k
hi EQ2008,
i have a contractor on hand which he had just done up my new BTO at woodlands. quote are reasonable and everything fits to my design. PM me if you need his number.
  • 1 month later...
Hi there, I am looking for a contractor to reno my 3 rm resale.
Would any one be kind enough to email me the quotation and ID/contractor ?
MASONARY WORK
KITCHEN:-
@430sqft
WC/BATH:-
LIVING:-
MASTER BEDROOM:-
flooring @313sqft
FALSE L-BOX
of Living Hall
PLUMBING WORK
area
b) Accessories $100
c) 2 x Basins $90
d) Shower Mixer $80
e) WC $50
ELECTRICAL WORK
LAMINATED FLOORING
WINDOW AND GRILLES
WINDOW AND GRILLES
CARPENTRY WORK
Kitchen:-
CARPENTRY WORK
Living Hall:-
system @ 6ft
Master bedroom:-
a) Swing door
Bedroom 2:-
a) Swing door
Master Bathroom:-
a) solid surface
b) mirror
PAINTING WORK
new doors
swing door
PLASTERING WORK
HAULAGE FEE
hi eggarette
you may wanna try this ID who did up my house cheap and good and within my time frame. prices competitive and nice design concepts from him.
When my wife and I met up with him, we were impressed with his on-the-spot sketches and space planning. His patient approach and his wide range of ideas
easily answered our questions and queries.
After our discussion, we were telling ourselves that if his quotation is reasonable, HE shall be the guy to do up our house.
True enough, the next day he emailed us the quote and we got our wishes came true. Designer style and stuff with contractors pricing.
During the reno process, he was always at our house supervising the workers and making sure that works were carried out diligently..
Im the sort of person who has an eye for sore things. And I expected lots of works and finishings to be corrected and touched up. But he was always a step in
front of me. In the end, I would say he really made my life easy and surprised us with the quality finish and workmanship.
Looking back, My wife and I really got a gem and we are lucky to engage this ID for our dream home.
You can try contacting him as I believe he can definitely come up something special for your home.
( P.s. depending on your quotation, he can give discounts too. LOL. )
