Temporary Sound Proof Of Windows
Hi, I've recently rented a room in an apartment and found that after just a couple of nights, the noise from outside was really loud despite being on the 13th floor. After closer inspection, I noticed that there are large air gaps between the window fittings (as can be seen in the photos - light coming through gaps) which show absolutely no sign of sound proofing whatsoever. I feel that these windows were probably not originally designed for a bedroom!
Does anyone have any suggestions that could temporarily dull out some of the outside noise? It doesn't have to be perfect, but a small reduction in noise could make a big difference. I'm only here for 4 months so only temporary and cheap DIY methods, tricks or tips would be viable. I appreciate your time!
I have the same gaps along the sliding windows in my house. The is normal for sliding windows in Singapore.
Poor workmanship due to tendering process adopted by the developer (gov & private).
I do not think there is a solution for sliding windows. Can only live with it.
If you have curtain rods, maybe get some thick curtains (from IK**). It might block out some of the noise.
  • 3 weeks later...
  • 2 months later...
If you have a spare thick bedsheet, just roll it up and cover the base of the window should help a bit. May be unsightly though.
