Hi all,  i am contemplating the purchase of a unit and would like to check, from the floor plan, is the red circled area hackable? As it is indicated as a solid colour.
Not sure if its even a load bearing beam as the area is so small. Thanks for all advises.
As it is shown as a solid column, I don’t think it is hackable. You will need a registered PE to verify it if you still want to go ahead with the hacking. Sometimes HDB did allow it to be hacked.
