Ceiling Fan
Why don't you go for Google search...
Edited by Matthew99
  • Replies 951
  • Views 325.1k
Hi Bro,
Can PM the contacts for Franco fan as well.
TIA
Hi Mr Bro,
Can I also have the contact of your lobang?
Thank you...
Hi, I have two white colour kdk A11YS for sale.(ideal for Low Ceiling Types HDB) Just bought four of them last week but finally decided to use only two. I can show you the receipt as proof. The fans are sealed in the boxes, brand new, and have not been opened before. Am letting it go for $160 each. Please SMS me at 97803597 if you are keen. Thks.
Cheers!
Jenn
hi BRO,
can you kindly share your lobang? kopi on me.
I have a very high ceiling (pitch roof - floor to the highest point is 6m). i have no idea whether franco fan can customize the rod? any advice will be appreciated!!
thanks
Need advise, i intend to install KDK, 4 blade fan. At the surround area, L-Box with cove lighthing. In addition, putting projection screen and mount projector.
Question, i wonder if the fans height might block the projection. Anyone had similar setup and could advise ?
Hi... Can anyone tell me where r the places that i can go to where there r alot of ceiling fans on display? I m concerned with both the performance n aesthetic purposes :) Btw my id recommended me kdk, but i m stil undecided bet crestar n kdk :) Any advise or recommendations?
have you tried it online? There's a lot of sites that offers ceiling fans . I advise you browse the internet, and see different designs. So basically, you'll have idea on it, as well as compare features and prices. ;)
Hi, anyone has any electrician/installer to recommend? I never have ceiling fan installed before, so what to look out for? My ceiling got no hook and extra wiring for the ceiling fan. Looking at HDB floor plan, my living room is 5800x3500, is KDK baby fan suitable? THX.
Hi bro,
I've read in the forum that for KDK A11YS baby fan, one will only get the wind if one sits directly under the fan.
Is it true?
So if the fan is in the middle of the bedroom, beds & tables at the side of the wall, then we won't feel the wind??
You've lobang for KDK fan? Do PM me.
Thks very much :)
yes, kdk A11ys has limited coverage and about 45degree (dunno if you get what i mean). good enuf for me cos i dont need it to circulate my whole room (for the moment) and only need it to cool the sofa location which is directly below the fan. :P my living room so small and ht so low, so not much choice actually. :P
Hi booksntoys,
FYI, plate mounting ceiling fans is for low ceiling, if it's mounted on a high ceiling, you'll not feel the wind.
Cos the blades are close to the ceiling, therefore the air flow will not be as good as those down rod type.
Another point, plate mounting fans tense to create some wind noise when spinning on high speed.
So if your ceiling is high then go for down rod mounting ceiling fan, plate mounting ceiling fan is not a good choice.
Point to note, the size of the fan is the area that you wanna circulate, if you need to circulate bigger area then choose bigger fan blade size.
If u're located in the east then you can go to Tampines East CC, Macdonald's to see if the fan hv wind or not.
They've mounted a row of A11YS ceiling fans in the outdoor sitting area.
BTW I only hv FANCO lobang, i dun hv any lobang for KDK ceiling fans. :P
Hope this helps :)
Cheers pal ;)
Mine is 5-room HDB flat.
How's the review for FANCO fans?
What FANCO model would u recommend for HDB 5rm bedroom & living room?
My experience with elmark fans is that they'll weaken in speed & wind strength after years of usage.
Thank you very much for ur advice :)
ceiling fan is never meant to cool the whole place.
it can only cool a slightly larger area than its blades.
hence, its suitable for areas like above sofa and above bed.
i tried KDK babyfan during my stay at Tunes Hotel. Loved it so much that i got it for my house. During cool nights, just need speed 1, during hot nights just need speed 2.
speed 3 is not good, too powerful and noisy to be able to sleep.
