poorgirl09
Any Recommendation For Contractor Doing Windows And Window Grilles
Hi all,
Do your have and recommendation for good contractor doing windows and window grilles?
I really appreciate for your help...
Thanks a lot.
Btw, do your know how much will it cost for 4 room flat?
Hi all,
Thanks a lot.
PM me if u are still looking for 1... I think for both grilles n window could be around 2000-2500 ba... not sure.
Also depends on what you want:
1. Aluminum or Wrought Iron or just powder coated metal grills etc?
2. Materials for ALuminum with double hollow section OR solid core is more exp.
3. Glass for window also makes a difference... tinted green or blue glass i know is kore exp...
:dancingqueen:
:dancingqueen:
Thanks..I have PM yo le.
:dancingqueen:
You can contact Wei Renovation. See my signature
For alumn, stainless steel & wrought iron grilles, u can check it with:
Seng Cheong Alum & Renovation works at Blk 1 Yishun st 23, tel:96668951-Mr Meng
He do lwet works & roofing as well.
Most of the IDs' use Supreme Metal n Wan Shern aluminium works, as their sub-con for aluminium windows, bi-fold doors etc... I prefer Supreme Metal works for its efficiency in work schedule, worksmanship n prompt in responding... Contact Eric @ hp 9832 1380, say Pierre recommends n see wad u can get... ^^
my ID quoted me $1.7k for window grilles for living and 3 bedrooms... aluminium, with powder coat (not sure wad that means...) is this considered reasonable?
i am intending to do window grilles also. something like the picture below, just the middle portion where the windows swing out.
gotten a quote for sliding window grilles $480 which includes
3 x 5ft by 3ft 2-panel windows
1 x 4ft by 3ft 2-panel windows
1 x 8ft by 3ft 4-panel windows
for aircon ledge window, was quoted $54 for about 2.5ft by 3ft 1-panel pull-out (not sliding) style.
is the quote reasonable?
paisay, IMHO, it is over-priced liao.
PM u my contact le :dancingqueen:
For small items like tis, can consider ok la...
Its like quote for a 1k job, they earn 10%...
For $480 job, if earn 10% only, they eat grass liao... :dancingqueen:
Hope u can understand ar... :yamseng:
I'm interested also, Can let me know which contractor you get for the a/m quote. Look quite cheap.....Thanks in advance.
