My Cosy Home In Holland
Yes, according to HDB regulation. U can still install both at 2 toilets but when u selling house, HDB officers will request you to remove all unauthorised works. So u have to tear down your heater, electrical trunking and wires for either one of the toilet.
Since you install liao, be reminded not to use the heaters for both at toilets at the same time, if not it may trip the whole house electricity. Overloaded.
For me, i install heater at kitchen toilet. But master toilet i run the wirings only, in case i really wan to install heater in future. Nex time sell house, i will tell the HDB officer that i run the additional heater point by mistake but didnt use it. My wall also dun have drilled holes marking for the mounting of heater, so they can close one eye.
:D
i always hear people say cannot install 2 instant heater but i can't find the rule in the hdb reno guideline. only for those with 30amp main switch, instant heater cannot exceed 3kW. mine is 40amp main switch and there's no limit on the current. do u know where to find the rule?
  • Replies 924
  • Views 230.2k
  • it's been 4 months and they still don't have stock. if the price is too good, it may not be true anyway, they don't know when the tv will have stock. oh i am also trying to look for a wallmounted w
Ai ya.... BY right cannot... BY left .. just do it lor...
From my past experience, the HDB inspector will not ask so much and they usually will just pin point on the ceiling fan if it is too low. Normally if you want to sell the house then you remove it and put aside before going for the 1st appointment and completion for handing over to the NEW owner.
After that it is up to the NEW owner to install it back or throw away.
Don't have to worry... do whatever you want and if you need a "PERSON" to sign the letter for those unapproved items... I can recommend but need to pay a noble small fee for his signature..
This "PERSON" is also who I had used for my house and had set up all my installation of electrical works / lights / fan / heats / etc... *HINT*
:D
bro, i think HDB officer will be more concerned of concealed sockets than water heaters :D
HDB regulations didn't say cannot have 2 water heaters, but did say cannot have concealed wiring housing.
I haven't install yet and my electrician also never say anything about it. He knows I have 40Amp in and out (MUP) so he also never say anything about overloaded. Already told him will buy 707 Compact.
When I ask him, he say he put 2 sets of wires in my house, each heater runs on separate set of wires. I don't know what he means but he say if one side of the house trip, the other side of the house won't trip. Maybe next time I ask him to show me how to trip one side only :D
707 Compact is 3kW, 230V, 50/60Hz.AC so shouldn't be an issue.
I know who that person is :D Maybe should have hired your guy to help me do my electrical works :D Maybe next reno :D
Edited by ossify
Bought a 707 compact and a mistral MH3 today
$165 for MBR
Nominal Power Rating: 3kW, 230V, 50/60Hz.AC
Inlet Water Connection: 15mm Diameter
Outlet Water Connection: Threaded 1/2” BSP
Min Working Pressure: 2.5 Psi
Recommended Working Pressure: 14.5 Psi
Anti-Scald Device
Pressure Relief Device
Stabilizer Valve Control
Power Selector Control
Dimensions: 270mm x 215mm x 88mm
Warranty: 5 years on Heater Element, 2 years on other heater parts
$90 for common toilet
* Splash Proof
* Anti Scald Device
* Build in double heating element. Flow Sensor Device. Full Copper Inner Tank.
* Compact size
* Sliding shower set
Voltage: 110V,220-240V,380-440V~50Hz/60Hz
Power:3KW
Edited by ossify
posted this last time, found out the price today, it's $410 from A Lighting Enterprise, Alpha F360
Bought this at A Lighting Enterprise also... the price is cheapest of all liao. I saw the real fan at some lightings shop... really nice!
ordered a Baron 1pc white toilet bowl at $200 nett, to be delivered tomorrow.
Edited by ossify
ossify,
do note that for tis model of Baron, the distance between the back wall at which the WC is lying against, and the bottom of the WC, is very small... so if ur WC is slot in a tight space, it might be difficult to wash the small gap on the floor between WC and wall..
ossify,
how small is small? :D
my toilet area is used for showering too so would that be a problem?
i cant remem, if u free u go down asia excel in balestier.. they have the baron wc and casanova wc almost side by side.. both looks the same, but the bottom distance of casanova is bigger, so i went for dat.. same price also..
well, for me i wana minimise the cleaning and scrubbing la. hahha, so i got the latter to save me the hassle..
Which one are you referring to?
Edited by ossify
bottom one. 1022. oh yah maybe cannot fit into ur toilet.. the S trap thingy..
is baron w-303 or casanova 1022 better? in terms of water usage?
mine is 6" S trap.
can share where you got them?
mine is 6" S trap.
hi
my cassanova wc cost me $190...
bargain for best deal!
most shops in balestier charge like $299 and above ...
Edited by seashell
