Any Recommendation On Tempered Glass Door(for Kitchen Onli)
Hi all,
I'm a newbie @ forum. Urgently searching for RELIABLE quotes for my tempered glass for my kitchen. My current ID quote me almost 1.3k for the clear glass tempered plus tracks. I was wondering am I over charged or is this the market rate.. Anyone pls advise.. THKS :)
Hi all,
What's the length and thinkness of the tempered glass?
Sliding or swing?
Hi all,
Yours Overquote, I've got 2 share :-
TOP HUNG TEMPERED GLASS SLIDING DOOR
To Supply & install fix panel tempered glass at kitchen entrance $280.00
To Supply & install top hung tempered glass sliding door at kitchen entrance $700.00
Hello. That sounds quite reasonable. I'm also looking for the above. Can you PM me your contact?
$700/- for pc of tempered glass for the standard door size is cheap if is 10mm thk.
Can share the contact?
can pm me the contact please?
Hi all,
My quote from the id is as followed:
Supply install plaster U-beam box cornice with solid timber for reinforce support for sliding door track--$280
Supply install 10mm thick fix panel clear tempered glass to kitchen entrance as side wall (1800mm*2100mm-ht x 2 panel-----$520
Supply install 10mm think sliding clear glass door to kitchen entrance in top-hung track. (L900mm* ht2100mm) ---$680
I feel that the quote should depend on how wide the entrance is. It will be better if your id installs plaster U-beam box cornice to support the sliding door track.
which id is this? i would like to get a quote from him as well
hi, quote from my id for your reference.....
Supply & install U-box @ dining area ( for top hung sliding glass door ) 7ft - $140
Supply & install 10mm thick top hung clear tempered glass sliding door - 1 Set $650
Supply & install 10mm thick clear tempered glass fixed panel @ kitchen entrance 28SQFt - $420
cheers :)
  • 1 year later...
Kindly share with me the contact for tempered sliding glass door. I need 2 for kitchen and may need another one for another place. thanks!
