In Place Of Partition Wall..what Else Can Replace?
Hi all ,
was asked by FSM to erect a partition wall facing the door to prevent chi from flying out straight to the window. (door face window) .
it will be quite impractical to do so due to small space.. what are the alternatives? Tall plant? some hanging crystals ?etc ? please help.
cheers!
Hi all ,
cheers!
keep windows closed and curtains drawn?
if your main door is directly facing window. Easiest solution is to buy a "Ping Feng", it can keep the 'QI' in your house. Some people get those 2in1 type of "Ping Feng" which built in with shoe rack.
hi thanks. if i have space for a "Ping Feng", i would do so or built the partition .... but small space leh ... thanks anyway :)
Hi all ,
cheers!
Err.... Same quote from my Fengshui Master also, mine is main door facing directly to balcony.... I intend to place an altar estd abt 2.5ft(l) x 7ft(h) to block it anyway :) alternative, you can consider sliding divider :)
i think placing a tall plant can also help in this situation,
Hi all ,
cheers!
before tht overall ur hse good fs anot? if ur overall is good then if not practical, this issue shld be small issue..
