Any Parquet Flooring That Does Not Require Glue And Nail Down?
Reason is because I don't have the luxury of 2-3 weeks to wait for the glue to dry before the polishing/varnishing. Working on a rather tight timeline.
I've thought of laminate flooring, but I prefer the real wood feeling and don't really like the hollow sound that goes out from the laminate floor.
Appreciate any inputs from any of you! Thanks.
If dun have luxury of time, u turn on aircon full blast for ard continous 3 days. This will dry the installed wood really well
Try vinyl wood flooring
Hi, I think engineered wood could be the alternative. No acclimatization time needed, but you will need to have it glued down to have the solid feel.
Thanks for the inputs given so far.
I googled this up earlier and there is this thing called "floating parquet flooring" mentioned, which basically means that the installation is the same as click-lock mechanism that the laminate flooring used and does not require glue down.
Has anyone heard of this before, and is this the same as the vinyl wood flooring that jaskel mentioned?
  • 1 year later...
Hi Flashlight,
Bamboo flooring also can overlay on your existing floor without hacking them,
And it is also has a natural finishes,
may u want to consider?
Cheers
