How To Diy Toilet Led Mirror Lighting
Hi All,
Anyone can advise if the toilet does not have power points, how can I fixed led strip lightings like those in Ikea around the mirror?
thanks
Hi All,
thanks
Hi bro,
LED also need power supply be it AC or DC hor. If you think of using battery, I would say don't waste time, $$ and effect on it.
Hi All,
thanks
tapped it to the toilet light ? but you will have to do up the trunking....
u have to find someplace to hide the transformer, its not as easy as only 2 wires... perhaps u can put the transformer in ur room n run the DC wire with trunking to the LED, that will be safer
Rig up a solar panel with wires connected to the LEDs, bathroom light turn on the LEDs will light up, if lights off LEDs will not light up… haaaaaa
Hi All,
thanks
Thanks for all the reply. Guess will have to check with contractor to see what is feasible with ur commentst.
this will require a big big big BIG solar panel :D
