Edges Of White Laminate Kitchen Cabinet
For those using all white laminate for kitchen cabinet, can u see the black joining line at all the edge of the doors and the frames?
I saw some ready make white tv consoles, shoe cabinets, the edge are very smooth and u don't see a single black joining line.
but my kitchen cabinet can see all the edge joining lines. the ID told me because the back of the laminate is black color and when they join, the edge sure can see the black line, is this true? :o
remember reading somewhere in renotalk... for carpentry, usually ABS trimming are done on doors so the edge will be smooth, while for the main frame, trimming won't be done so will still see the joining line - did you specify ABS trimming for carpentry in the quotation?
as for ready-made one, usually don't have this same problem.
hope this helps :)
hope this helps :)
yea, standard practise is ABS trimming for the doors only.
the rest of the cabinets will not hv ABS trimming unless customer specify and is willing to pay for it.
one easy way out is to use a white paint marker and "paint" over the edges. but white is difficult to match. some white laminates are not pure white, but a little towards cream, or off-white. but those paint markers dun hv such varieties of white. only 1 pure white.
Join lines are visible for cabinets covered using laminates, unless
1. ABS trim is used
2. Colour core laminate is used.
The ready made cabinets you see may be spray painted using a high-gloss paint, which is why you don't see any join lines.
Hope this helps.
  • 3 months later...
i have the same problem!
my cabinets are already up...where can we get the abs?
  • 1 month later...
Abs trimming is a kind of edge finishes for cabinet doors. Must be specified to the contractor before installation.
Abs trimming can be applied to all cabinet doors, with additional cost.
Another more costly edge trimming, will be compressed doors...
How much will ABS trimming cost? I don't think I specified this to my contractor either. :(
  • 5 years later...
Hi, so with ABS trim, I shouldn't see the joint lines? Because even after ABS trimming, I can see joint lines. Would that be because of poor workmanship?
Also, my contractor said that I have to use a different colour for my ABS trim because the colour of my cabinet laminate is a bit unusual. Is it better to just have the edges done with the same laminate? Will there be more wear and tear without ABS trim?
  • 1 year later...
The black line is because of the base of the laminate - there are two types: white and black. you will not see the line if it is white based but that will be more expensive. For the black one you can use a white paint marker or paint. I am in the same situation and my contractor tried to use paint on it but he did such a bad job that it got frustrating. I think a white paint marker from popular will be better and I am going to do it myself
