Need Advise On Quotation - Toilet And Kitchen For 19k?
Dear frens,
I am new to this forum and recently just brought a new resale 5rm flat. I was being quoted the following for toilet and kitchen, total around 19k? Can someone advise if this is too ex, since there's no hacking of tiles, quotation is for overlay only!
Masonry work.
Supply and overlay selected floor tiles for kitchen. $1,450.00
Supply and overlay selected wall tiles for kitchen. $2,950.00
Supply and overlay selected floor tiles for SCV balcony. $650.00
To construct 50mm height cabinet base with side tiles finishing. $150.00
To construct 50mm height washng machine tiles finishing. $150.00
To construct 50mm height fridge with tiles finishing. $150.00
To construct 2nos. Shower kerb for 2nos. Bathrooms. $240.00
Supply and overlay selected floor tiles for 2nos. Bathrooms. $900.00
Supply and overlay selected wall tiles for 2nos. Bathrooms. $2,900.00
Carpentry work
Design and fabricate L40fts kitchen cabinet in solid plywood with laminate finishing with ABS trimming door. $4,400.00
Supply and install 1nos. Stainless steel dish tray. $150.00
Supply and install L18fts surface counter top for kitchen cabinet. $1,170.00
Design and fabricate 1set solid plywood with laminate finishing and ABS trimming door suspended cabinet cum solid surface counter top vanity cabinet with mirror set at master bathroom.$1,250.00
Plumbing work
Supply and install stainless steel piping for kitchen and 2nos. Bathroom. $750.00
Supply labor to install kitchen sink, tap c/w drainage system. $85.00
Supply labor to install bathroom accessories. Foc
Supply labor to install 2nos. Instant heater.. $120.00
Supply labor to install 2nos. Toilet bowl. $240.00
Supply labor to install 2nos. Basin. $120.00
Tempered glass work
Supply and install tempered glass shower screen at common bathroom $450.00
Supply and install tempered glass shower screen at master bathroom $450.00
Door work
Supply and install 2nos. Aluminum frame with PVC panel bi-fold door at 2nos. Bathroom. $440.00
Hacking work;
Labor to dismantles existing kitchen cabinet.
Labor to dismantles existing toilet bowl , basin,etc.
Labor to dismantles existing bathroom door.
Supply labor and transport to clear renovation debris.
Sub total; $950.00
Total: 19,165
Thanks very much!
Dear frens,
Masonry work.
Carpentry work
Plumbing work
Tempered glass work
Door work
Hacking work;
Sub total; $950.00
Total: 19,165
Thanks very much!
Its reasonable :yamseng:
For your reference - Items for kitchen and 2 toilets
(Kitchen)
Demolition Work
01. Hack off existing floor tiles
02. Hack off existing wall tiles
03. Dismantle existing kitchen cabinet
04. Dismantle existing water pipe
05. Dismantle existing wiring / casing
Wet Works
06. Provide building materials
07. Provide designer wall tiles ($2.80 psf) max. 400sqft
08. Provide designer anti-slip homogeneous floor tiles ($3.20 psf)
09. Apply waterproofing membrance using 104 Quickseal
10. Provide labour to construct kitchen cabinet base
11. Provide labour to construct fridge base
12. Provide labour to construct washing machine base
13. Provide labour to lay kitchen wall tiles
14. Provide labour to lay ktichen floor tiles
Plumbing Works
15. Provide labour and materials to install new stainless steel water pipe (cold)
16. Provide labour and materials install new inlet / outlet pipe (PVC)
17. Provide labour to install 1 set of kitchen sink and tap
18. Supply 1 set of stainless steel double bowl kitchen sink
19. Supply 1 set of kitchen sink tap
Electrical Works
20. Provide labour and materials to install new casing for kitchen
21. Provide labour and materials to install 2 nos of lighting points
22. Supply 2 sets of ceiling lights
23. Provide labour to install 2 sets of ceiling lights
Carpentry Works
24. Design, fabricate and install 20 feet ktichen cabinet with ABS trimming in laminate finish
25. Fabricate and install 10 feet kitchen top using solid surface
26. Provide labour and materials to install 1 set of built in dishrack
27. Provide labour and materials to install 1 panel of stainless steel backing at hob area
28. Supply 1 set of branded stainless hood
29. Supply 1 set of branded glass hob
30. Supply 1 set of cutlery tray
Miscellaneous
31. Provide cardboard protection during renovation
32. Chemical / Acid wash after renovation
(Master and Common Bathroom)
Demolition Works
Dismantle existing pedestal bowl
Dismantle existing wash basin
Dismantle existing bathroom accessories
Wet Works
Provide labour to construct shower kerbs
Provide labour to lay wall tiles
Provide labour to lay floor tiles
Plumbing Works
Provide labour to install 2 sets of pedestal bowl
Provide labour to install 2 sets of wash basins and taps
Provide labour to install 2 sets of instant heaters
Provide labour to install 2 sets of bathroom accessories
Supply 2 sets of otto / baron dual flush pedestal bowl
Supply 2 sets of otto / baron wash basin
Supply 2 sets of wash basin tap
Supply 2 sets of instant heaters (Customer Choice not excess $200.00)
Supply 2 sets of 7 pcs bathroom accessories
Supply 2 nos of wall mirror
Electrical Works
Provide labour and materials to install new casing for both bathrooms
Provide labour and materials to install 2 nos of new heater points
Miscellaneous
Kitchen at $12,880 + 2 Bathrooms at $8,900 = $21,780
Promotion Items
Supply and install 01 set of 1 fixed + 1 swing shower screen using 10mm thick clear tempered glass - $358.00
Supply and install 02 sets of aluminium bi-fold door at $158 each - $316.00
Total: $22,454.00 ($12,880 + $8,900 + $358 + $316)
Edited by blackwhite.sg
Dear frens,
Masonry work.
Carpentry work
Plumbing work
Tempered glass work
Door work
Hacking work;
Sub total; $950.00
Total: 19,165
Thanks very much!
can i be invite to quote also ..
i will do it for 18500...
Dear frens,
Masonry work.
Carpentry work
Plumbing work
Tempered glass work
Door work
Hacking work;
Sub total; $950.00
Total: 19,165
Thanks very much!
Think too expensive.
Saw a Pormotional Package at an ID Firm in TradeHub 21. Resale HDB 5-room Apartment for Kitchen & 2-Toilets, at $16,800. This offer includes hacking of old tiles on floor & wall + new waterproofing.
Was told they are a new branch and offering cheap now. Showroom around 1500sq.ft.
If interested can PM you their Package.
Edited by PapaYeo
thanks papayeo! Can you pm me the package info?
those packages normally have a lot of missing items, like kitchen cabinet includes only 10 ft while you actually need 20 ft. so after adding all those, probably close to 19k liao :P
Sorry, tried but still dont know how to PM, lol.
or can you PM me your email instead? Sorry.
Exactly! Headache. The ID quotes me 40ft for the kitchen cabinet - for top and bottom. But when i check with other IDs, the kitchen is at most going for 30ft, minus off the area for fridge. So he his quote doesn't seems to provide a more accurate measurement.
U can see my T-blog for what I have done, and it cost a total of $37K.
For toilet and kitchen, i just calculated those portion from my quotation and amounts to about $15K.
