My New Home - Serangoon 4 Room
From what I can see in your common toliet, the exposed piping at the bottom might be a problem in the future. Dirt and mould might grow in between the areas of the connectors for piping to wall and if you accidentally hit on pipes, it might get ripped out!
BTW, did you install valves along the water piping? It could be used for emergency when your tap leaks or water fixtures burst.
Yar, the pipes would trap dirt. We will just have to clean it more often. But to hit the pipe until it gets ripped out should be quite rare. My old toilet was done this way, and 26 years, didn't see the pipes get ripped out.
No, we didn't build valves along the piping. So if it burst, our only valve is the main valve .
  • Replies 220
  • Views 87.1k
  • Serangoon4room
    Serangoon4room
    Anyway, since i'm back to renotalk, let me share with you my home experience after 2 years... 1. Recommended my contractor to 2 other friends. Good feedback from the first one, but poor feedback from
  • Serangoon4room
    Serangoon4room
    yes, i have to slowly lower the cables from the hole in the middle to the bottom. Makes it more difficult when you subsequently have to add new cables through the middle hole to the bottom where the f
Did you tiled the opposite wall of your kitchen cabinet? Any picts...
Thanks... :D
Nope. We didn't have wall tiles in our kitchen. There will be glass works on the side of the wall with the stove. The other side is just plastered wall. Using paint only. No pics to share currently. But having out kitchen using more white laminate makes our kitchen look bigger.
Another bad news... Although Terence agreed to change doors, the design i originally chose is discontinued... Terence showed me the new catalogue and I had to choose another design.. Still using maple color but Walnut wood on both sides instead of just one side.
Today Terence just informed they will complete by next Thurs. 2nd Chemical wash is this saturday. Renovation is finally ending... Can't wait...
Edited by Serangoon4room
Thanks... I am thinking of doing the same thing and am concerned about the maintenance...
The new paints are supposed to be very washable, so maintenance wise will not be as bad. ME and wife don't foresee we will do a lot of cooking hence we didn't see the need to have the wall tiles.
If you do a lot of cooking, you may want to have wall tiles or a very good hood to suck away the oily smoke from your cooking.
:dancingqueen: Congratulation. A journey coming to an end...
Congrats! Everything Is looking good and ready move in. Happy move in :)
Mmmm... thanks... Will factor the "cooking" part into the consideration... Haha...
Haiz.. have to delay handover to next week cos there's too many outstanding things to fix...
Living room
Hollow Tiles
Uneven patches on top of kitchen entrance
Unvent patches below Aircon
Main Gate has hole not filled on top
Main door has holes not filled at lock area
Kitchen
Floor Stains
Solid surface white paint stains
Solid surface crack near powerpoint area
Kitchen tiles gaps not filled up.
Glass backing not up.
Common Toilet
Floor Stains
Hollow wall tile
Study Room
Poor paint job
Ceiling hooks not removed near window and near the light
Guest Room
Poor paint job
Curtain Pole not removed.
MBR
WIW edge at entrance not covered.
Hollow Floor tile
MBR Toilet
Screen door not up
Box up not up.
Toilet floor tiles spoilt due to WC installation
Water Pipe into Toilet not covered with Wall Tiles
Towel Rack crooked.
To all areas
3 Room Doors not replaced yet.
All holes removed must be filled up, plastered and repainted.
Found many hollow tiles in my Living room. Terence will be changing but he mentioned it may result in very slight uneveness as the replaced tiles may not flush perfectly... this got me thinking but what the heck, there's too many hollow tiles... Buckling would be a worse problem for me in the future.
At least, our Muji Dining table is here!! and so is the dressing table.
They should change all the tiles in the living room, rather than telling you that there is slight uneveness. That's not your problem for causing that, isn't it? My parents' house has many hollow tiles and the tiles pop up after 10 years. If you are not staying the flat for long, I think you shouldn't ask them to redo, but it all depends when the tiles will pop up.
Sorry to hear about your issues, I also had to move in without doors and other issues due to FS timing so it was super messy and dirty while they keep doing different works everyday. May they all be rectified soon and your muji furniture looks good!
I like ur muji dining table.
Sorry to hear abt many defects.
Hope all will be rectified to good condition.
New fixes to my place.
New Doors!!
Old Doors..
My Bedside cabinets
