getzski
Single's Home In Bedok Res
it's a $1.80 sticker from gmarket. over 100s to select.
So, it is a sticker. Btw, Where is gmarket?Thx :)
from far it looks good, but once you get nearer you will see bubbles and imperfect edges along the switch due to my poor worksmanship.
next try will be better. :)
kitchen shelves are finally done....yeah!
Hi getzski, chk with u, with ur black 3D glossy wall tile instead of glass backsplash, how u find e cleaning after cooking? Any difficulty? Also, any complaint with ur gas heater? Last qns :P What is e cost damage of ur bathtub? Is there any min. width req to have a bathtub? TIA
hi purplefairy,
it's tiles. they are very easy to clean. i wish i had choose the same tiles in the toilet, cos those in the toilet are tougher to clean.
ah...yes....i'm starting to have issues with my gas heater. sometime when i'm in the middle of a shower, the flame extinguishes. it is a on and off problem, and i'm still trying to figure the source of problem? but i still like the heater as compared to instant heater, and my shower section looks more sleek....lol
the bathtub is from a bathroom speciallist in tagore lane. i got it at $170 duing their warehouse sale. it is a 1.5M long bathtub. you need to do your own measurements, and allowance(30cm to be sure) is needed for the tiled area of the bathtub. no approval is needed. bathtub is very light. acrylic material i believe. the most expensive part of the bathtub area is not the tub itself, but the labor/construction the contractor will charge. you could almost buy a fancy built-in jacuzzi with the same amount of money (i.e. if you can find one at <2k)
Getzski, max has heater running is 15 mins. Then it will auto off. So you need to shower then switch off the water to soap yourself then on again. If you on the hot water and stand under shower for more than 15 mins, then it will off.
