Need Rough Estimate for Granite & Parquet Polishing
Hi ,
I am in the process of firming of my ID for my HDB resale EM renovation work... I need to check here for an realistic estimate if I want to do Granite floor Polishing as well Parquet varnishing/sanding/polishing ?  The rough estimate of my work below...
1) Supply labour & materials to polish existing granite flooring for living area est. 730 sqft
2) Supply labour to varnish parquet stairways and passage way est. 110 sqft
3) Supply labour & materials to varnish existing Parquet flooring for Level 1 (all 3 bedrooms) est. 520 sqft
How much would this cost & How much time it needs ? Thanks
  • 1 month later...
previously I got quoted for 1.50 psf for marble polishing. parquet polishing for rooms is $600 for 3 rooms. staircase not very sure as I don't have stairs at my house. hope it helps
Dear Kelvin
Many thanks...with each ID companies quoting differently hence asked your help.
Thank you for your inputs and will work through with similar approach ...regards Jega
  • 2 months later...
Do not know if you done the polishing as i will be able to help with this
  • 3 months later...
  • Popular Post
You can also DIY the polishing yourself if you want
You can polish/recondition your granite/parquet tiles by using something called HCL89
What it does is that it polishes and reconditions your granite/parquet tiles and also helps to create a protection for it so that always remains new.
You can usually get it from from http://hcl89.byethost10.com or http://hcl89.atwebpages.com
Hope this helps you out ;)
  • 1 month later...
TS are your tiles new or already aged and polishing it for the first time?
  • 4 months later...
I think maybe its a resale flat since he needs to have the tiles polished
  • 5 months later...
For staircase and floor polishing i remember the polishing rates should be different because of different materials
Thank you all
It was for my resale EM flat with existing floor tiles & parque on 3 bedrooms and staircase
I have done already with my reno ID
  • 10 months later...
That means if its the same material the polishing rates should be the same?
  • 2 years later...
When it comes to tile polishing is not only the type of tiles that determine the price but also the type of polishing involved as well
