Quotation for 5 room resale OVERHAUL
Hi All!
As I'm pretty new to this, hope to get your advice on whether my ID quotation has been overpriced.
Some info:
5-room resale flat (27 Years)
Requires full overhaul
Quotation
Hacking, Haulage & Preliminary Works
  • Hack existing whole house wall & floor tiles
  • Hack kitchen wall
  • Dismantle & Dispose Balcony Aluminium Sliding Door
  • Dismantle & Dispose Living/Dining Full Height Storage Cabinet
  • Dismantle & Dispose Kitchen Cabinet & Stove
  • Dismantle & Dispose 2 x bathroom fittings
  • Dismantle & Dispose Simple cornies
  • Dismantle & Dispose Main gates (Door & Frame)
  • Dismantle & Dispose 3 x Bedroom Doors & Frames
  • Dismantle & Dispose 2 x Toilet Doors & Frames
  • Supply & Lay Corrugated Paper (Single Layer) for Floor Protection
  • Haulage of New & Raw Materials
  • Clearing of Debris
TOTAL HACKING,HAULAGE & PRELIMINARY WORKS: $6,300
WET WORKS
BALCONY
  • Supply & Lay Homogeneous Floor Tiles : $800
LIVING/DINING
  • Supply labour and material to cement screed living & dining, 3 x bedrooms : $4,770
KITCHEN
  • Supply & Lay Homogeneous Floor Tiles : $2,500
  • Make Good Hacked Area at Kitchen: $300
COMMON TOILET
  • Make good hacked door frame: $150
  • Supply & Lay homo wall tiles: $2,200
  • Supply & lay homo floor tiles (includes waterproofing): $720
MASTER TOILET
  • Construct Tiled Cement Base for Shower Screen: $100
  • Supply & Lay homo wall tiles: $2,300
  • Supply & lay homo floor tiles (includes waterproofing): $790
Make good hacked doorframe x 4 : $600
VINYL FLOORING
  • Supply & Lay 5mm vinyl flooring w/skirting ****/DINING: $2,380
  • Supply & Lay 5mm vinyl flooring w/skirting at 3 x Bedrooms: $2,560
CEILING
  • Construct False Ceiling ****/DINING (includes curtain palmet): $2,200
  • Construct False Ceiling at MASTER BEDROOM (includes curtain palmet): $700
CARPENTRY WORKS
BALCONY
  • Design& Fabricate half height suspended shoe cabinet w/ settee     | 8 Feet: $1,440
LIVING/DINING
  • TBA
KITCHEN
  • Design& Fabricate Top & Bottom Kitchen Cabinets                                    | 39 Feet: $5,850
    Includes: Hyadraulic Hinges for Flip Up Doors
    Includes: 1 x Wooden/Aluminium Frame w/ Frosted Film Glass w/ BLUM AVENTOS SYSTEM
    Includes: 1 set 304 stainless steel drip dry dish rack
    Includes: 1 set PVC Cutlery Tray
    Includes: 4 sets of 50kg soft closing BLUM DRAWER TRACK
  • Supply & Install iQUARTZ Top as Kitchen Work Top                          | 15 Feet: $2,100
  • Supply & Install iQUARTZ Top as Bar Top Counter (w/wood base support for bar top)              | 5 Feet: $900
MASTER BEDROOM
  • Design& Fabricate Full Height Sliding Door Wardrobe w/ Dresser    | 18 Feet: $5,075
MASTER TOILET
  • Design& Fabricate suspended vanity cabinet/mirror     | 3 Feet: $540
  • Supply & Install iQUARTZ Top for Vanity Cabinet          | 3 Feet: $420
PLUMBING WORKS
  • Supply & Connect Single Copper Piping for whole house ( 1 x Kitchen, 2 x Toilets)
  • Labour to install kitchen sink & washing machine inlet/outlet piping
  • Labour to install kitchen sink & tap mixer
  • Labour to install 2 x bathroom wash basin & tap mixer
  • Labour to install 2 x hot water point
  • Labour to install 2 x instant heater
  • Labour to install 2 x pedastal W.C.
  • Labour to install 2 x bidet spray
  • Labour to install 2 x shower head
  • Labour to install 2 x bathroom accessories (7pcs)
TOTAL PLUMBING COST: $1,850
PAINTING WORKS
Painting Works  for Whole House         $1,850
Includes: Painting Net
Note: Ceiling Emulsion Paint Only
Note: Painting Works is Subject to max 2-3 coats
Includes: Sealer for Whole House
OTHER WORKS
  • Supply & install 10mm clear tempererd glass shower screen at MASTER TOILET  $760
  • Supply & Install Nyatoh Door Frame x 5: $750
  • Supply & install bedroom laminated doors x 4: $1,600
  • Supply & Install Laminated main door x 1: $600
  • Rubbish Chute: $220
  • Washing for whole house x 2: $350
*Windows, 2 toilet doors, aircon & electrical works not included yet*
TOTAL COST: $50,655
Edited by tiffanytlh
Adding
hi tiffanytlh,
saw ur quote, certain things a bit on the higher side. ceiling, plumbling, glass...
but not the extend of very expensive. just my thought. maybe ur ceiling is very special designs?
35 minutes ago, alantang said:
hi tiffanytlh,
Hi Alan,
Actually my ceiling is just a normal false ceiling across to hide all the electrical trunkings. Is it too expensive based on market rate?
hi tiffanytlh,
ya, its very expensive. should be 1600-1800 only depends on ur size.
plumbling and wardrobe also on the higher side too. i do my shower screen only 500.
if u feel good with the id, then go ahead n ask for discount. most important u must be
happy and comfortable too.. :)
hi tiffanytlh, your hack works and tiling works is a bit high. I had pm u the direct hacking and tillers contact to try asking them
Hi, your price seems to be quite steep. If you like, i can share my contractor's contact with you.
