Quotation Help Appreciated
Professional Services
Space Planning
Design Consultation
Furnishing & Deco consultion
Perspective drawing
Materials & colour proposal
Site supervision
Whole Unit
Painting for whole house (wall&celing)
Painting for all doors & frames
Painting for gate & all pipings
Revarnish of existing main door
Plastering of all existing wall groves
Living/Dining Area
2ft x 2ft polish homogenous floor tiles for living area
2ft x 2ft polish homogenous floor tiles for dining area
Polish homogeos floor tiles for household shelter
Homogenous or laminated skirting for whole house
Construct main entrance kerb
Alteration of exisiting main gate
Erect L-box light holder **** area
Erect L-box light holder at dining area
Erect false ceiling at foyer area
Erect false ceiling at bedroom's passageway
Main Bedroom
HDF laminated flooring w/ underlaying
Laminated skirting
Construct L6ft laminated build in wardrobe (ABS trim)
Main Toliet
Construct shower kerb
Supply & Install 10mm thick tempered glass frameless show screen
Extension of water pipes
Connecton of all piping works
Running of drainage piping works
Labour to install instant heater & toliet accessories
Bedroom 2
Laminated skirting
Bedroom 3
Laminated skirting
Common Toliet
Kitchen Area
Construct kitchen cabinet base
Construct fridge base w/ tile finish
Construct washing machine base w/ tile finish
Connection of all piping works
L20ft Kitchen Cabinet
ABS door trim finishes
Supply L10ft postform kitchen worktop
1 set of stainless steel dish drying rack
1 no of kitchen cutlery tray
Labour to install sink, hob & hood
Imported stainless steel designer handles
Hydraulic stainless steel door hinges
Package for EA till here is $13268
Omission Items
To design & fabricate L6ft laminated build in wardrobe in ABS door trimming finishes $1200
Additional Items
Structure works
To demolish existing wall at study room $350
To demolish existing wall at main bedroom & bedroom 02 $380
To construct wall using hollow block c/w door frame at bedroom 2 $650
To construct wall using hollow block c/w door frame at main bedroom $450
To supply & install 1 set of full height glass panel c/w swing door at study room $1350
To supply & install fixed tempered glass panel at main toilet (L0.8m) $380
Haulage fee for uploading/downloading of materials and town council fee $500
Carpentry Works
To design & fabricate L3.2m partial of design feature wall c/w door & laminated shoe cabinet at storeroom $1700
To design & fabricate 1 set of L2m laminated TV console w/ rotatable pane at livingl $1600
To design & fabricate 1 set of L3.2m laminated L shaped suspended work table at study room $1200
To design & fabricate L4m laminated wardrobe at main bedroom $2500
Total damage $25528
Hi.I am no expert but look ok.. but for the kitchen cabinet.. postform is not the norm now... ask for solid top but the price may change.. U will also have other $$ like electrical..can cost quite a bit..not much help..sorry
For the whole package:
1) Tiles: What are the range of tiles u can get to choose? Also what is the psf tiles u can choose?
2) Paintings: How many colors to choose from? What are the range of paints u can used?
3) Laminated: What is the brand of laminated flooring and skirting u are getting? 5mm, 12mm or enginner flooring?
4) Toilets: If want to change to storage heater how much is it? How many toilet accessories i can install within one toilet? What are the types of pipings? stainless steel or copper?
5) Kitchen cabinet: What is the brand of laminate i get to choose? Thickness of ABS trimming? 2mm or 1mm?
It will be good to know what are the materials u are getting. Try to take a look at some of their current project base. Go to some of their ongoing renovation so u will get a better picture. Dont just to sign up just they are cheap or other reasons.
Each cents counts as per material being used. Thickness of the material plays a role too.
Hope it helps.. :dunno:
well, these are some of the standard questions you should be asking to see if the quote you got is worth its value
1) how much psf is the tiles you are allowed to choose?
2) Solid surface... what brand are you getting? from the pricing it looks like Cresto, Acelite... or something in that range.
3) Laminates... what brands are you allowed to choose from?
4) electrical, lighting, fixtures like installation of cooker hood and hob, water heater... etc is not included.
5) additional costs like shifting of water pipes is also not included
6) Water piping for the kitchen only? not extended to the toilets?
7) Any protection sheets during the reno to cover the floors after the tiles are laid?
8) Painting... how many colors? is white considered one of the color choice? (white should not be!)
what brand of paints? is it wash and wear or matt?
how many coats of sealer used before painting?
how many coats of paint are you getting?
will simple plastering be done to smoothen out the wall before painting?
9) do a simple measurement for your L-boxes... if they cost >$10 pfr, you should re-negotiate the price ;)
10) Laminates at the three bedrooms... what brands and range are you allowed to choose from?
you got an EA unit? demolishing wall between MBR and BR2? :P got a unit in seng kang is it?
removing the study room to make a bigger dining area? :notti:
the stuff you got quote including the optional stuff is quite good... but you must ensure that the material are good.
You may want to top up for a solid top for your kitchen. And 20 feet of kitchen is DEFINITELY NOT enough! You may have to add to that as well... why? well, if you do it like what most people do for their kitchen, that is top and bottom cabinets... you will actually have only 10 feet of work top to use. Minus 3 feet for sink and 3 feet for hob, you actually only have about 4 feet of work space left... put your rice pot, hot flask and spice rack on that 4 feet, you are only left with about 2 feet of work space... where got enuff?!?
so, ah gong is advising you to relook your kitchen cabinet dimensions ;)
hope it helps :D
Yup its at JW planning to hack the study to make a bigger living area. Have to hack between MBR & BR2 because of odd shape, thanks for your advise.
no problem! PM anytime if you need help
am always lurking around :P
all the best to your reno :notti:
