Sewage Smell From Toilet
same problem. Engage HDB, plumbers, personally apply additional sealant around the joints. Nothing work. Finally, notice same phenomenon as one forumer pointed out. suspect there is a back flow into my piping system. Nothing much I can do except to flush every time the pungent smell comes up.
  • 4 weeks later...
  • Replies 34
  • Views 59.3k
I got this problem too. Later realised it is WC's pan collar problem, as described by Brainstorm.
At 1st, the ID told me it's due to the neighbour below, ask me to pour bleach into the drain pipe. No use. HDB guys came, also no use. Then a contractor told me to cover all the drain pipes holes. Stuff with wet cloth and seal it as much as possible. This is to identify where the smell come from. Cover all pipes still got smell ... so the culprit must be the toilet bowl. Finally ID asked his contractor to remove and redo the toilet bowl again. Two month of foul smell finally gone!
I have a feeling it might be a leak at the cement skirting around the toilet bowl, hmmm
  • 3 years later...
