Aircon Quotes (From Aron)
Hi Aron,
I need to redo the pipings for my current system 4 aircon & also rearrange the inverter systems at my place. Can you quote me please! Thanks in advance.
  • Replies 2.1k
  • Views 658.2k
  • I was told my a saleman selling aircon that the default grey insulation is good enuff if your aircon trunking is expose as most of the HDB are. And not hidden as those in the condominium. Armaflex ar
  • ok, there are retailers who try to cut corners to save $$. eg. they offer you system 3 at (est) $3.4k, generally the air-con mfgr specs will specify wat type of material to use, eg. for insulation, pi
  • i got a quote from gain city. Mitsubishi invertor, compressor is 30k btu, then 3X 9k units for 3 rooms, and a 22k unit for the living area. Cost is $3.4k. is it cheap? TO be honest, im a noob when it
You quoted me Mitsubishi. I'm asking for Panasonic.
Thanks.
I have just PMed to you.
Thank you,
Aron (aronputt@gmail.com)
Kindly quote for system 2. Thanks.
Thank you,
Hai, can you quote me Mitsubishi starmex system 3 (10K, 10K, 12K)? Upgrade piping. How much can I get? Thanks
Thank you,
Hi Aron,
Thank you,
Hi Aron,
kindly quote for suitable sys3 models for old HDB flat with 8.5A limit.
Thank you.
Hi Aron,
Thank you.
Thank you,
Hi all renotalk members, we are running a special air-con promotion for MITSUBISHI STARMEX:- (Please email aron at aronputt@gmail.com for this promotion)
A) Special Renotalk Price: $3850 nett for Mitsubishi Inverter system 4 (new model, 18kbtu + 9kbtu X 3)
B) Special Renotalk Price: $2999 nett for Mitsubishi Inverter system 3 (new model, 9kbtu X 3)
B) Special Renotalk Price: $2899 nett for Panasonic Inverter system 3 (new model, 9kbtu X 3)
C) Special Renotalk Price for brands like daikin, toshiba, LG etc. Single Split, System 2/3/4 available for both inverter and non-inverter.
* Free & no obligation Site Survey
* Free 2 trips installation (1st trip to run piping, 2nd trip to put up air-cons [if needed])
* Free dismantle and disposal of old air-con
* Free upgrade to Armaflex class “O” 1/2 inch thick insulation,G23 copper pipe,keystone cable (made in singapore),16mm drainage pipe
* Special coordinating work between us and customer’s contractor
* Special appointed installation team
* Special supervising work by head of installer
Terms & Conditions
*All promotion items while stock last
*All prices include HDB standard installation
We have set up a facebook page (link below) specially for you and all Star Cool customer who will like to seek for after sales service, air-con advise and quotation. Please kindly dropby and give us a like if you are satisfy with our services.
This facebook page will also serve as a channel for you to contact us if you have any enquiry in regards to your aircon.
Thank you,
Aron
Hello,
whats your price for:
Starmex
24K btu
13K btu
10K btu * 2
38K btu compressor
thanks!
Hello,
Starmex
24K btu
13K btu
10K btu * 2
38K btu compressor
thanks!
Thank you,
Hi Aron,
Could you please recommend & quote me for Mitsubishi system 2 for 3 room flat.
Please indicate the model of the air-con & material to be use & is there any needs for air-con bracket?
Thank you
Please quote me for the following:
Mitsubishi Electric StarMex 28k BTU multi split system 3 inv aircon
MXY 3A28VA (28K BTU)
MSY GE18VA x 1
MSY GE10VA x 2
Please also let me know the type of copper pipe, drainage pipeline, insulation material and thickness that you use, as well as how many times installation works provided?
Do state the warranty provided with the aircon purchase and the period of coverage too.
Installation required for a Condo unit. Thank you.
Hi Aron,
Can quote me for Mitsubshi starmex sys 2 - 9K x 2? Old HDB may need backet but not sure.
Tks.
Hi Aron,
Thank you
Hi Lin,
Thank you,
