vermyapre
Electrical work cost??
My electrician referred by ID charges me (26 July 2008)
Each
5Amp light and cornices light point - $35
13 Amp double power point - $55
SCV point - $100
Switch - $50
10 AMp MCB - $30
Cooker hood and hod point switch - $100
Fixing door bell and light - $10 (kan na sai)
Fixing light and cornices light - $10
Shifting 13A point $20
Okay? Or I kanna chop :dunno:
yuo, looks like u kena chopped big time..........
Ex hor...ok here's my breakdown:
Living/Dining
New Lighting point: 13x$25 = $325
Looping for lighting point: 9x$18 = $162
2/way light switch control/concealed: 1x$40 = $40
Concealed light switch cablings: 3 Lots x $90 = $270
Relocation of lighting point = 3x$20 = $60
Relocation/concealed lighting point at ceiling = 1 Lot = $90
Relocation of SCV point = 1x$75 = $75
Relocation of 13A double power point = 1x$40 = $40
New 13A double power point = 1x$60 = $60
Relocation/concealed 13A single power point = 2x$70 = $140
Relocation/concealed existing light switch cabling for balcony = 1 Lot = $70
Kitchen
New lighting point = 3x$25 = $75
New 13A single power point – concealed = 1x$85 = $85
New induction hob point c/w DP switch – concealed = 1 Lot = $100
Concealed light switch cablings = 1 Lot = $90
Bedroom 1
New lighting point = 1x$25 = $25
Concealed light switch cablings = 2 Lots x $90 = $180
Relocation/concealed of SCV point = 1x$95 = $95
Relocation/concealed double 13A power point = 1x$80 = $80
New 13A double power point – concealed = $95
Bedroom 2
New lighting point = 2x$25 = $50
Relocation/concealed existing light switch cabling = 1 Lot x $70 = $70
Master bedroom/Toilet/Walk-in-wardrobe
New lighting point = 9x$25 = $225
Concealed light switch cablings = 3 Lots x $90 = $270
Concealed lighting point at ceiling = 1 Lot x $80 = $80
Relocation/concealed telephone point = 1x$70 = $70
Termination/isolation of existing flooring power point and SCV point c/w proper cable-link works = 1 Lot x $50 = $50
Installation of light fixture/bell = 51x$10 = $510
Supply dimmer c/w concealed box = 5 Lots x $60 = $300
Total is $3922, after GST is $4196.54
Guest our-home
We just received quotes from 2 contractors (not ID) for some electrical work:
New lighting point: $60, $50
Labour to install light fitting: $20, $12
1 13amp single: $90, $50
1 13 amp double: $100, $75
1 SCV point: $180, $135
My hubby and I think these people added "fuel surcharge" into their prices. And it could also be that, as some forummers have mentioned, quotes for HDB and condos are different.
At this rate, looks like we're going to have to cut down more things we wanted to do/change in this 8-year old unit.
Quote for haulage & chemical wash: $600, $1500 (such a vast difference from 2 contractors!). This is just one example. Don't know where to start bargaining ...
That's really costly! 8|
For mine, I am not sure if its expensive anot... I did full house, wiring, re-locate some wires and points, total for 4 rm flat is $1,500.
At first I think he quoted hubby $1,700, but we bargained as ours is new flat and my sub con also told me for new flat should be around $1,500 for everything....
hope that helps...
Guest our-home
ourhome
maybe u can get another contractor
hehe
Yep, looking into that.
Otherwise, we'll consider making do with candle-light.
hi,
my id's electrician provided this quote:
Supply & Install New Lighting Point - $35.00 x32
Supply Labour For Install Light Fitting - $14.00 x44
Supply Labour For Install Pendant Light Fitting - $50.00 x1
Supply & Install New 1X13A Point - $70.00 x1
Supply & Install New 2X13A Point - $90.00 x3
Supply & Install New SVC Socket Outlet Point - $90.00 x2
Supply & Install New Weather Proof 1X13A Point - $120.00 x1
Relocation Of Light Switch & 13A Socket Outlet - $40.00 x3
Installation Of Speaker Cable Point - $90.00 x2
(Cable Not Provided)
it this considered a fair quote?
thanks!
duckweed
is urs concealed?
if not its quite expensive esp for new points
i'm totally unfamiliar with these electrical stuff. but mine will be all concealed. expensive? i'll be getting at most a 5% discount off the prices above.
hi all my electrician charged me as below =(
light point - 22 pcs x $50 = 1100
double ( ??? ) - 3 pcs x $65 = 195
heater point - 1 pcs x $80 = 80
scv point - 1 pcs x 110 = $110
wiring for 2 way switch - 2 pcs x $60 = $120
hager big switch ( all ) = $ 280
install all light - 6 pcs x $10 = 60
total $1900
seems ex?
  • advertisement_alt
  • advertisement_alt
  • advertisement_alt
