3rm In Tampines
Due to some hiccups (hospitalization), reno was delayed for about a week. Since then, had confirmed lighting plans and done rewiring, s/s water pipes, confirmed colours and painting in progress (10 colous in total excluding oil sealant)
painting was supposed to be completed yesterday but painter was rather slow, will be completed by tomorrow.
laminates up today, will post pics tomorrow :)
carpentry to come in next monday! exciting how it will turn out.
solid surface expected to be installed next friday.
main door and gate the week after and that's a wrap.
Edited by ossify
  • Replies 149
  • Views 38.5k
Back to promoting yourself. How was your Air-Con installation? Was your AC plan workable?
How much are you charging for 10 colous painting Job in a 3 rooms?
Edited by HDB Officer
Hi David, want to chk with you. We were very happy with the painting and all last night(viewing them using torch lights) but we jz came back from the house and were left puzzled by a few things. At the first few quotations, before our meeting with your foreman, you state a few plaster here and there to cover the ugly parts of the house. Bt thn during our meeting with your foreman, he said that it's better to get the whole house plastered and that he will plaster the ceiling to cover the groove lines in every room of the house. Because of this, i decided to get you to plaster the whole house. So we were puzzled as to why we still have the grooves in the ceiling of every room. I didnt say anytin d last time cause i dont know what's happening at all for the reno. And thought that maybe you will finish them up when you come back from the hospital. So now i just want to know, is the plaster job not intended for the ceiling? Cause i paid for that fter your foreman told you that it will look nicer if i had that part plastered.
Another thing would be the lighting and fan point in the living room. After the electrician left i asked where the lighting points would be, and you said should be where the 2grooves are and we'll be following the previous owner's lighting and fan point. But we were dissapointed to see that the positions were different than what we discussed about. The reason why we are unhappy is because there are so many lines on the ceiling now. And that point brought us back to the fact that the lines wasnt plastered smooth at all!
On another note, we cant close the mbr's door. We cant even push forcefully as the paint might come off.
This reno is taking longer and longer to complete. And i cant help but feel frustrated.
Cool down hush girl, he's the reno consultant, he will know what to do, even if its illegal.
Finally it's completed and handover on Tue 31 August
Some pictures to share
Living room, facing kitchen
Living room, facing away from kitchen
Kitchen
Sink cabinet
Induction hob cabinet
Edited by ossify
More pics
Soft close
Swingslide door for storeroom
Found a hole in the floor while doing cleanup, caused by careless subcon :(
After patch up (informed owner about hole, offered to replace damaged plank out of my own pocket)
Edited by ossify
bro, tot this is samsung irex soft-close hinge? blum's damper is much bigger...
More pics
This is not Blum at all....don't anyhow said..or u charge owner Blum cost but give otherwise.. :unsure:
Look like your planning for water and air-con pipeline don't work at all.
yup you're right! it's Samsung
Edited by ossify
nope, didn't charge for Blum cost, just soft close
owner decided not to do L-box so plan changed.
anyway, not sure if the shop (authorized dealer) i found is cheap for blum stuff... one piece of the damper is $1.90 and the butterfly hinge is $1.40, a total of $3.30 per set....
For me, I'll plan the wiring and piping on the same wall as its will look nicer but still u r at the site, u know better the situation there. But 1 more thing, is the motar base more than 50mm?
Yes, its cheap. :good:
oh great!!! maybe can buy some to get my carpenter to fix it.... they oso sell the blum runners for non-blum series usage, at $30+ per set after discount....
