Calcution For Kitchen Cabinet Quotations
Hi
In the process of obtaining quotations for job to be done for my kitchen, I realised various contractors have different method of quoting. Which is the most equitable and fair method?
Method 1 - For doing top and bottom cabinet, they calculate by adding the total length of the top + bottom x $ pfr
eg. Top = 8 feet, Bottom = 8 feet. So, they add together = 16 feet x $100 pfr
total = $1600
method 2 - top cabinet is $90 pfr; bottom cabinet is $100 pfr.
so, 8 x $90 = $720
8 x # $100 = $800
Total = $1520
method 3 - top + bottom / 2 x higher rate pfr eg $220 pfr.
16/2 = 8 feet x $220 = $1760
So tricky.....can people here advise which method is the norm?
thanks
I think more impt is the quality of workmanship n materials…
How about the solid surface top? You need to add to the cabinet cost, correct?
I have gone through 6 ID recently for my new house renovation and all of them are using method 1.
Even my contractor used Method 1.
Solid top was quoted seperately as below.
Measure the length of bottom cabinet (which needs to be covered by solid top) X solid top cost in pfr (per foot run)
If the contractor lumps the cabinets, Solid top together we can always ask for break-up so that we can compatre the quotes.
Although top cabinet uses slightly less material coz it's recessed as compared to the bottm, but it still equates to the same amt of work to mfg the cabinets. So norm all contractors should be using Method 1.
Yes, you need to add it.
  • 5 months later...
Hi
total = $1600
so, 8 x $90 = $720
8 x # $100 = $800
Total = $1520
thanks
hi hi this is interesting to note! i've got another add on question for L shape cabinet...isnt there a double counting at the right angle then?
:o:o thats alot for top and bottom cabinet!!!!!!! not forgetting the granite top costs......omg correct me if i'm wrong pls
Edited by sng28
Hi
total = $1600
so, 8 x $90 = $720
8 x # $100 = $800
Total = $1520
thanks
Method 1 is common.
I agree with the saying that workmanship is important.
Beware some carpentry work uses some very bad China made, cheap quality laminate.
Some pfr can be as cheap as below $100.
