Cost Of Tilting The Main Door
Anyone here has experience on tilting the main door of 5 degree? What is the cost and recommended contractor(s) who can do it? Appreciate your info. Thanks!!!!
What is your original door facing?
Thank you.
Tilting door involves a lot of work, hacking is unavoidable, it will damage your flooring and wall holding the door frame when taking down the old door and door frame.
Then lay new floor tile(try to find closest matching tile), re-construct door frame, install new door, i think must be fire grade.
Yup, a friend did one, heard appx few hundred. Don't know which he used, forum got so many contractors, try to get some quotes
Thanks for the advise. Is it true that new hdb does not allowed tilting of door? Any recommended contractors? Thks
Need HDB approve.
Cannot happy happy tilt the door
Part of the main door frame is embedded into the concrete floor, to tilt the main door will cost you a bomb, new door frame would not be as solid as the original and must get HDB approval.
  • 2 years later...
Just to share this Feng Shui article about main door and it stated otherwise.
Is tilted door good?
But this is just for reference, there is no right or wrong.
hmmm...did FSM say he will money-back guarantee if it didn't succeed to prosper u after that ? And if this don't succeed he'll probably suggest tilting windows, move furniture and last house.
:good:
is this worth all the trouble? what exactly do you seek then ?
He 'thinks' worth to try to get out of present 'slums', via 'outside-in' methodology.
Can you teach him the 'inside-out' method?
Need HDB approve.
Just curious.
Has HDB ever gave approval for this? If yes, is the owner obliged to restore the door to its original state when selling the unit?
Cheers!
Anyone here has experience on tilting the main door of 5 degree? What is the cost and recommended contractor(s) who can do it? Appreciate your info. Thanks!excl.gif!
Yes, i did before 28 degree for fire rated main door... cost abt $2388 included box up and plaster by the side of main door...
After that got 'easy to huat'? 28 or 2.8 deg ?
https://www.google.com.sg/webhp?sourceid=chrome-instant&ion=1&espv=2&es_th=1&ie=UTF-8#q=tilted+door+images
One degree tilting already very 'jialat'.
Perhaps residential door design should follow that of air-bridge's, can tilt at any angle till you 'huat huat huat' or 'can't recognise own home'?
https://www.google.com.sg/webhp?sourceid=chrome-instant&ion=1&espv=2&es_th=1&ie=UTF-8#q=air%20bridge%20images
