Back To The West
  • Replies 931
  • Views 279.8k
  • OceanEleven
    OceanEleven
    Lighting for the living, dining and kitchen, all the same except in sizes. All from Tmall and lighting known as Smithfield. 4 lights for RMB830, what more can one ask for? 3 sizes OD 60cm/48cm/35cm. C
  • OceanEleven
    OceanEleven
    This was how the balcony look like after all had been tore down: Now after the white powder coated full height window & grill are installed. The balcony leveled and flooring laid. Pardon the dark
  • OceanEleven
    OceanEleven
    TV Console. Fits up to 60 inch TV Slots for Sound Bar and below for any other players etc Right at the bottom, house for Robotic vacuum cleaner.
Posted Images
Today marks the start of electrical fittings installations.
Wow..... a lot of switches :jawdrop::jawdrop::bow::bow:
Wow..... a lot of switches :jawdrop: :jawdrop: :bow: :bow:
Actually this does not cover the whole house. Those hidden are supplied by electrician.
Bought a kettle from Amazon but arrive with a blemish.
Paint peeled off. Luckily got a full refund. Still, I rather have a good kettle.
Bro
Is there a lot of dust flaking off the wall?
Surprisingly, there is nothing much coming off the wall now.
I was expecting when wipe across with hand, there will be white powder.
But there are nothing, unless of course if you rub hard.
Currently bracing for the walls to "dry" further or expand and see if crack lines etc will appear.
If there are, it will be normal, especially if that wall gets lots of sun.
Edited by OceanEleven
Bro, is this the same kettle? Looks good! How is it? Can use for induction stove? Free shipping above USD125?
Brother ocean, for the kettle how does the power socket look like? Is it the US 2 pin kind? Cause I bought one kettle from amazon and when it arrive the plug is not the standard 3 pin kind
Yup, this is the same kettle. Induction should be able to.
Free Shipping above USD125. :lol:
Hi there, this is a hob kettle, not a electrical type.
Find electrical type a tad too costly in the long run.
In your case, you will need a UK power plug adapter and a power converter.
Easily available in hardware/DIY/Fix it shop.
Need to take note what is the watts of the appliances before you buy the converter.
Power Adapter
Power Converter
