Possible To Polish Glazed Porcelain Cermic Tiles?
I need advice on polishing of floor for my upcoming HDB flat.
As the flat is a premium flat, which comes with the flooring, I want to make it look nicer by polishing.
Might need feedback from the forum:
(1) Is it possible to polish Glazed Porcelain Ceramic tiles with timber skirting?
(2) If possible, will like to some recommendations from the forum as I cannot find any vendors on the Internet.
Great Help is really appreciated.
Thanks!
  • 1 month later...
  • Popular Post
In my case i use something called HCL89.
I usually get it from http://hcl89.byethost10.com or http://hcl89.atwebpages.com
What it does is that it cleans your tiles, renews or cleans the tiles and also helps
to create a protection for it so that always remains new.
Hope this helps you out :)
Edited by Ziad
  • 1 month later...
By glazed, you mean matt or glossy?
  • 4 weeks later...
  • 4 weeks later...
Hi all,
Sorry for the late replies..forgot to check whether there are any updates on this question..Thanks for feedback.
The tiles has a matt finishing( not shiny or glossy).
  • 2 months later...
Then where is the timber part? You mean its at the side?
  • 1 month later...
He mentioned its the skirting, so it should be at the side i think
By timber, it's the skirting around the perimeter of the house.
Ceramic tiles are not possible to polish as far as i know. But glossy homogenous tiles are possible to polish; meaning it can be grinded / sand to a super shiny an flat surface. You will not even feel the grout lines later.
  • 2 months later...
  • Popular Post
Its a bad idea to grind glossy tiles, it will damage it, don't do it
  • 1 month later...
Ah ookay now i know what he means ;)
  • 2 months later...
  • 2 months later...
  • Popular Post
This skirting is all over the house or just a smal area?
  • 1 month later...
Should be just living room, i think from the way TS described
  • 6 months later...
From what i know ceramic tiles should be able to be polished
  • 2 months later...
On 17/05/2015 at 1:43 AM, TedDibiase said:
I thought grinding only for non glossy right?
Should be from what i know as well
