Impress21 Design And Build - My Home Makeover
DAY 1 The Beginning
Works:
-Hacking of floor tiles in kitchen, yard and yard toilet including WC and basin
-Demolition of kitchen door and door frames, and cabinets
Before pics of kitchen
  • Replies 231
  • Views 129k
  • Some pointers to share and lessons learnt during my makeover 1. Prepare. I am always prepared before every meeting with the contractors. I have a list of things prepared to ask and discuss with the c
  • BAY WINDOWS cont The yard ledge was given the treatment too, and it has been a breeze wiping it clean...and its very hard wearing that it can withstand heavy traffic if used on floors. I treated m
DAY 1 cont
Before pics of Yard
After hacking
Kitchen door removed
Whats underneath the door frame...these excesses can be removed to further widen the doorway
DAY 1 cont
After hacking
Sink area - notice the cracked tiles after door frame removal - its inevitable
Gas pipe exposed - yellow marking indicates concealed gas pipe underneath
Some pointers
1.Removal of door frames will inevitably result in damaged tiles. Make sure you have spare tiles for replacement, if you intend to keep your existing tiled wall.
2.The door kerb under the frame may be affected
3.Replacing door frames can be more expensive than the door itself
mmm thanks for the tips. *shall not replace doors to save some money* :P paint paint paint..
DAY 2
Works:
-Hacking completed, and debris removed
-Discussion with chief tiler and electrician
After hacking cont
Yard and toilet
Met Darren, the electrician, discussed my requirements - 2x20A point, extra concealed sockets, positioning of electrical points and new switches, running the wiresT5 lighting, replace switches, install lightings
DAY 2 cont
Met chief tiler, Ong, discussed tiling works - direction of laying, skirting, kerb, and cabinet base construction
Selected the middle tile - its the whitest homogeneous tile available in Hafary. Price $3.20 psf ( no need to top up :) )
Drawing by Ong
DAY 3
Works:
- Commence tiling works and construction of cabinet base
Yard WC - confirmed sewage hole distance from wall is 10 inches. All the other WC measured the same 6 inches from base to wall.
Called up shop to informed them - I have ordered the 3 sets of WCs and basins, and plumbers are coming next week.
DAY 9
Works:
- Electrical
- Plumbing
- Meeting with chief carpenter
The "fun" begins today, the above people are coming as tiling and kitchen base are all completed. Lighting stuffs and appliances all delivered.
Kitchen
Yard
Yard toilet - so much better, if you look carefully, there is a slight gradient to prevent water ponding which was a problem in the original state
Close up of the tiling in toilet - looks good
Electricians doing the wiring...Darren is up on the ladder to lay wires in the false ceiling
My final electrical works:
Kitchen ---- 2x20A socket for oven and induction hob
2x13A for dishwasher and hood
3 double sockets
Wiring for T5 lighting drawn from kitchen lighting( switch to change to 2 way )
Living ----- Hack and conceal one dimmer socket
Replace 3 water heater switch, all switches, and install lighting
DAY 9 cont
Newly hacked concealed sockets for dishwasher and double socket
Closeup of the dishwasher and double socket
Newly hacked concealed sockets for 3 appliances - oven, hood and induction hob, and a double socket ( not shown in pic is another existing double socket to change faceplate )
Closeup of the wiring for the 3 appliances - daunting
Closeup of the concealed double socket
:jawdrop: love ur layout leh, got utility room somemore...
hi
keep those pix coming... :)
DAY 9 cont
Wiring completed
A look at the kitchen doorways
Kitchen entrance
Skirting -- still rough (awaiting the plastering contractor )
Skirting the other side
Skirting along kitchen wall
DAY 9 cont
Kitchen back entrance
Closeup view
The other side
The skirting below
DAY 9 cont
Skirting at the utility room in yard ( aka maid's room converted to storeroom )
Next ... the plumbers. Yard toilet was done first
Yard toilet installation
Below basin and view of the WC
As so many things were going on, it was hard to trying to keep an eye on everyone, and later after a review of the photos, discovered....
The basin tilted...
Same with the common toilet basin...
Already plastered :( Informed Henry...he said could be the wall or basin not vertical, but no problem, will rectify the next time :good::)
Tips
1. Remember to take photos....you can sit down and review at the end of the day, and pick out what you may have missed
2. Remind your plumber to use a spirit levell to mount your basin..I remembered a forumer mentioned this in his blog, but I forgot all about it amid the flurry of activities..... Luckily can be rectified..whew
3. Remind the plumbers again touse protection when they install your precious shiny taps and bath accessories...I specifically told them I dont want to see any scratches :)
----to be cont---
Edited by oogachaga
hi
Thanks...converted to storeroom, big enough as a maid's room :)
Sure...will keep updating...
we have the same basins and toliet bowl! :yamseng: from elbano?
by the way, what is a spirit leveller ar?
thks!!
