Feng Shui Tips
My room has whole stretch of wardrobe full of full height glass. On another wall a 37" TV. All facing my bed. I sleep about 6 to 7 hours everyday and wake up fresh.
I hope you don't mistaken. I'm just puzzled and curious when I read about this and hope you'll explain more why is it so? Or maybe share which book you read from or course/master you learnt from. If you don't intend to share, it's alright. No obligation, its respected. (But don't tell me again 'believe it or not')
Thanks.
Hahahaha, But i still have the same reply, you can dont believe it. If you feel well and good with mirrors facing you, good for you.
there are more then a 100 schools of feng shui out there, everyone has their own theory. I dont want to start a never ending debate.
  • Replies 274
  • Views 74.5k
GPP,
This the same website u prev pm me or another?
nope this is different, it is more for personal development. not feng shui related
Yes Sir. You are right...
I'm just trying to help you substantiate the point. :)
我們限在我是內通常會擺上梳妝台,或是衣櫥
為更衣方便所以都會有大面之鏡子,
但如果擺設錯誤,讓鏡子正對床鋪。
那可會嚴重影響睡眠品質和身體正常代謝,
夫妻容易口角和濫桃花之效應。
所以不可不慎
化解之方式
最徹底之化解方式就是將鏡子移到不會正對床舖之處。
如果無法移位可以暫時先用厚布(不可用透明之薄紗或是蕾絲材質)蓋上
要用時再先開也可以達到一定之化解效果。
Hi Swift, thanks for your help.
Sometimes when people dont believe in certain things they can choose to walk away, other prefer to pick a fight.
I refuse to fight, not because i am weak. It is just that I am lazy, there are more important things to do. hahaha.
What I can do is, if no one believes me i will stop giving tips.
if you guys prefer chim chim but good feng shui website and books i will PM u the site, but then you wont understand what it is about.
A doctor can tell you wants wrong with your body and give u medicine or injections or recommend u get sugery.
It will take years for you to have the experience like a doctor and to understand what happen to your body.
But if the doctor give you simple tips like eat more vege and fruits and less fatty and sugary stuffs you will understand.
A doctor talk at a level of you level of understanding does not means , he is at your level of understanding.
Hi GPP,
Jus back track and does another read up again on this thread. Think most of us cant afford to hire FSM to follow us thru all house hunting/site surveying before deciding one. Therefore, I wonder how does one choose a house with FS that suits him/her (base one ones ba zi??). ??
It seem a myth then when some FSM recommend "certain direction/certain part of sg" base on one ba zi without actual "internal and external" site FS auditing?
Here is the procedure for classic xuan kong feng shui audit in order or piority. If you look at this, you will see that BAZI is quite low on the list.
There are more important things to check. There are also more advance things as well like which storey and Pai Long (angle to road junction)
Check facing angle
Check energy chart
External environment
Main door, window and balcony’s energy
Toilet and kitchen’s location
Current walk path design
Good energy duration of the house
Energies of individual rooms
Energy of kitchen
Member’s birth data
Linking of pathway
Aircon/ bed/study locations, colours and elements of each room
With so many things to look out for, its really difficult to give tips on how to choose a good house.
At least choose one that the toilet and kitchen is not at the centre of the house.
Also if possible find one that have water and then mountain elements infront and behind your house. (water = river, roads etc. mountain = taller buildings)
e.g. you see roads, then building infront and behind.
Some house need water in front mountain behind,
some need mountain behind water in front,
some needs both water and mountain in front
while some needs both water and mountain behind.
If you have road and building infront and behing, we can at least have a choice to activate or de-activate it later when you consult a classical xuan kong feng shui master.
even this advise is still very general, the different shapes of roads and building results in different effects too....it is still better to invest one time in a good feng shui master. and not everyone is expensive. shop around first.
Check facing angle
Check energy chart
Energy of kitchen
Member’s birth data
Linking of pathway
GPP thanks for ur prompt replies..
Seem like its getting to b more interesting than expected. Guess its for me to hit book store for some elementary FS books. Keep ur tips coming GPP~!
Mirrors
Someone PM me to ask me a question about mirrors.
It is best not to have any mirrors in the house, but then again, it is not pratical, if possible use the ones that can be hidden in wardrobes.
Mirrors reflects energy. it reflects good or bad energy at the opposite end, depending on the month, every month energies changes.
It make the space have unpure energies.
If you have mirrors infront of your bed, most likely you and your spouse argue often. this one has been found to be consistant.
sometimes even tv have reflection, its good to cover it when not in use if it face your bed.
聽說家裡不能隨便掛鏡子。可以談談那些地方是禁區?那些地方能有越掛越旺的效果嗎?>
這真是一個很好的問題。各位不要以為只有白雪公主的後母才有一面魔鏡,每個人家裡的每一面鏡子,在風水上都有它的‘魔力’存在。
先談談家中最不適合放鏡子的幾個地方:
第一,正對大門的牆上不適合掛鏡子。正對大門的鏡子,會使家中 ‘氣虛’,以致家運難以提昇。(請參考 大門內的玄機 中玄關的注意事項。)
第二,臥室裡不宜有鏡子。尤其是希望能生兒子的夫妻,鏡子很可能會使希望落空。(請參考 臥室之其他 中 ‘臥室五不宜’ 的第一不宜。)
第三,廚房裡不宜放鏡子。可能造成水火失衡,帶來許多禍事。(請參考 勿讓廚房招災惹禍 中的 ‘問題四’。)
第四,廁所裡不可以當門立鏡。會使得廁所的穢氣在家中橫流,以致招小人,惹是非,煩惱多多。(請參考 廁所是必要之惡。)
那麼,那裡最適合掛鏡子呢?
首選之地,應該是有家庭聚寶盆之稱的 飯廳。在這裡放鏡子能夠增強聚寶的能力,增加家庭的財富,是最能讓鏡子發揮‘魔力’的地方。不過也有一點忌禁,需要注意。(請參考 聚財的飯廳佈置法 裡面討論 ‘鏡子的效用’ 的一段。)
先談談家中最不適合放鏡子的幾個地方:
那麼,那裡最適合掛鏡子呢?
:) maybe i should write in chinese too, sounds more fengshuiiiiii
Edited by GrandPaPa
Water feature
Many people think that having water feature or aquarium will bring wealth into the house, that is only half true (half false).
Where to put water feature is very important, if that sector is a bad sector it will actually activate disharmony, illness, scandal and other bad things.
But if you put it at the right place it will bring wealth. It is better to seek professional advice before you decide where to place the water feature.
But then again... there are so many lousy Feng shui master out there...maybe its better not to seek their advice...haha
Some things to take note,
1) Keep the water clean!! Dirty water dont bring wealth and dirty water if place at bad sector will multiple more bad things!!
2)The size of the feature must be propotional to your house or room. Feng Shui is about balance, if the balance is upset, doesnt matter if you put it at the right place.
3) Loud water flowing/gushing sound is unfavorable to family cohesion, do not think that water sound means good for wealth.
4) You will also need to know if that area needs Yin or Yang water. If that area need moving water, placing a tank with one fighting fish does not help.
5) Of all places, DO NOT put water feature in North sector this year until 4 FEB 2010, illness and all bad things will be activated, if you dont belive, you can always put it there and share your experience here. haha
GrandPaPa
:“润万物者莫润乎水”,客厅中的鱼缸,离不了水,所以鱼缸在风水学里是“水”的同义词,除了有观赏价值之外,在风水方面亦有其接气化煞之功效,鱼与水共生,使室内更有生机,并对家居风水产生积极的作用。因此,浴缸的宜忌即是水的宜忌,两者大同小异。
那些生辰八字缺水的人,摆放鱼缸在客厅便会对运程大有帮助,但那些忌水的人,若养鱼在客厅中,便决不适宜。如果不知道自己的生辰八字是否适宜养鱼,最简单的方法便是以自己过往的经历来验证。若是以往在家中养鱼而家运兴旺的。便应该继续养鱼,即使搬了新屋,亦不能中断。但若是以往家中养鱼而宅运不宁的,则尽快停止养鱼,甚至按风水论与水有关的物件也不要摆放在客厅中。
  在客厅中摆放鱼缸有以下几点需要注意:
  A、鱼缸不宜过大;太大的鱼缸会储存太多的水,从风水的角度来说,水固然重要,则太多太深则不宜,而鱼缸高于成人站起时的眼睛位置便是过高,因此客厅中的鱼缸不宜过大过高,尤其是对面积细小的客厅更为不宜。
  B、鱼缸不宜放在吉方;任何住宅都不可能十全十美,总有些外煞之类的存在,用鱼缸来化解外煞是其中的一个巧妙办法。风水学中有“拨水入零堂”的说法,所谓“零堂”是指失运的衰位,其意是指把水引入失运的方位,可以转祸为祥,逢凶化吉。因此鱼缸宜摆在凶方,而不宜摆在吉方。
  C、鱼缸切勿摆在沙发背后:从风水角度来看,以水来做背后的靠山是不妥当的,因为水性无常,倚之作为靠山,便难求稳定。因此把鱼缸摆在沙发背后,一家大小日常坐在那里,便会无山可靠,影响宅运的安定。而若是把鱼缸放在沙发旁边,则对住宅风水并无妨碍。
  D、鱼缸切勿与炉灶相冲:鱼缸多水,而厨房的炉灶属火,因为“水”与“火”相冲,故此客厅的鱼缸倘若与厨房的炉灶形成一条直线,这便犯了水火相冲之忌。鱼缸与炉灶对冲,会对家人的健康有损;原因是水火相冲,水能克火,受害的是属火的炉灶,而靠这炉灶煮食的家人,也会因而连带受害。此外,鱼缸摆放应尽量避免与神台成一直线相冲。
  E、鱼缸切勿摆在财神之下:正如俗语所谓“财归财位”,所以福禄寿三星这类财神便应摆放在当旺的财位,这才可锦上添花。若把财神摆放在鱼缸之上,就大错特错。因为鱼缸本应放在住宅凶方,倘若把财神摆放在鱼缸附近,这便与“财归财位”的原则矛盾,而且把财神摆放在鱼缸之上,那便犯了风水学的“正神下水”之忌,会有破财之虞?
  F、议养鱼数目宜与户主的五行配合:到底在鱼缸中养多少条鱼才符合风水之道,主要应根据户主的命卦五行而定。
  “河图洛水”的天地生成数口诀云:“天一生水,地六成之;地二生火,天七成之;天三生木,地八成之;地四生金,天九成之;天五生土,地十成之。”根据以上推定,只要找出户主的命卦五行,便可查知应该养多少条鱼来配合。
Shoe Cabinet
Many people like to leave their shoes and slipper outside the house or inside the house exposed and not hidden. especially near the door.
the door is an important qi opening, it it is untidy, dirty or smelly. it will bring in bad qi. when good month good energy comes to your door, it will be minus away by your smelly and untidy shoes and slippers. if bad energy comes it will be mulitplied.
Keep your shoes and slipper hidden preferably in a shoe cabinet. make sure it dont stink!!
在风水学上,鞋只适宜摆放于大门口附近,却不宜放在屋内其他地方,包括睡房。
 上街穿的鞋,沾染了金、木、水、火、土五行的气,通常比较杂乱,故只适宜放于经常出入的大门附近。如果把鞋子四处乱放,外 面“不好的气”将会随鞋子进入屋内,直接影响屋中人的运程。所以,家居最好添置一个鞋柜,将鞋子全部放进柜内,不好的磁场便无法随便释放出来。
 对于大门面向走廊的家居,鞋柜更可兼作屏风之用,阻挡由大门直冲而进的煞气。至于不曾穿过上街的新鞋,或供室内专用的拖鞋,放在家中任何地方都没有问题。
 至于鞋柜摆放的方向也要注意。一家之主若从事文职工作,宜把鞋柜放置于家中的文职位,即东南方;蓝领工人等靠劳力谋生的朋友,则宜放于武职位,西北面最有利,有助事业更上一层楼。以上的方位长年适用,勿须每年转换。鞋柜通常是多层式设计,以风水角度来说,鞋柜以五层高为佳,皆因这代表五行并存。鞋柜少于五层问题不大,多于此层数则属大忌,因为鞋属土,应该“脚踏实地”,将鞋放得太高的话,便会影响穿者。走路时容易扭伤、跌倒。再者,鞋子代表“根基”,根基打得稳,有助事业发展理想。
 同样道理,每层鞋柜最好摆五对鞋,以达致五行平衡的效果。
 另外,尖头鞋,鞋头最好向柜内放,否则,每次打开鞋柜取鞋的时候,鞋尖对着自己,形成火煞,久而久之,对健康有害无益。
Bells and wind chimes
I realise some people like to put metallic bells and wind chimes at the door, so that when people open the door they will know. especially for shops.
you will need to be very careful of metallic bells and chimes. sounds from them are strong metal elements. although it is very effective in weakening bad energies like 5 yellow that causes bad and negative things to happen. It may affect your wealth if put wrongly.
first of all from now till 2023 the wealth elements from flying stars are 8,9,1 which is earth, fire and water.
if you understand how elements react to each other,
metal attacks earth 8 (weaken 8)
fire 9 attacks metal ( 9 becomes weaker)
metal produce water 1 ( 1 become stronger)
if your door is capturing wealth star 8 and 9, having a metallic bell in front will weaken your wealth !!!
However if you house is having wealth star 1 then it might be good to have.
If after putting the bell and realising your business become worse, the best thing is to take it down.
Please let me know if you like the tips, then I will write more. :D
GrandPaPa
風鈴在風水上時常被用來擋煞或化煞,它所產生的音頻可帶動屋內的磁場,在玄空派風水學上常把它視為化解五黃煞的利器,所謂的「五黃煞」,主的是疾病與瘟疫,在此煞位處懸掛一只風鈴即可洩掉此類煞氣,此外住家如被對家的簷角沖到也可以用風鈴來擋煞。
“水能載舟,亦可覆舟”,風鈴若是掛的地方或是外形、種類不對的話,非但不能化煞,反而會因為它的「聲煞」而引來一些陰的東西,尤其是居住在山中或門前面對樹林、竹林的住家為甚,而一般風鈴儘量不要掛五層或五瓣的(以四或六層較佳),材質以銅為主,陶瓷其次,顏色最好是金或綠色。
多数人都懂得挂风铃会招鬼。但风铃作为吉祥物确实能化解土煞,而且还可以达到招财进宝、招贵的作用。但因大都数人都有惧鬼的心理,所以一般人是不敢使用风铃的。但若能用正确的方法挂风铃是不会招鬼的。
   首先记住东北方和西南方为鬼门方,如果大门开在此两方再挂上风铃是会招鬼魂的。所以大门开在东北方或西南方的,不宜在家门口挂风铃。
   话又说回来,如果家里真的有鬼魂缠绕,不管大门是否在不在鬼门方,风铃却是要挂在东北方或西南方的鬼门位。在鬼门方挂上风铃后,当鬼魂听到风铃之声,便被招来,而经由鬼门,鬼魂就有出路,而鬼魂就往生去了,即挂风铃是可以驱鬼的。但此方法只能判断出家中有鬼以后才能使用,把鬼魂驱赶走后,就不要再用了。否则,在鬼门位的风铃又将鬼魂招来,也就是说风铃确实有招鬼的功能。这就好像治病一样,如果你有病就吃药,病可治好;如果你没病而乱吃药,却会吃出病来的。所以家里没有鬼魂,不要把风铃挂在东北方或西南方的鬼门方位上。
Hi RIC and thanks for the add ons infos in mandarin.. :)
Sigh... maybe must write in chinese then people will believe me....haha
what i have shared is the basics of the basics of feng shui, have not gone into the complex stuffs yet.
if you engage a fengshui master and he does not tell you this, either its so basic he forgot to mention or he dont know....
Edited by GrandPaPa
Hi, can anyone enlighten me what '廁所裡不可以當門立鏡' means? very much appreciated :)
Means mirror cannot face toilet door.
