yes his pricing definitely includes drawers
in fact the usual cabinets comes with one set of drawers, but he didn't charge me anything although mine are all drawers :P
General Works
can negotiate further after you have meet up with him
OK
Masonary Works
Construct fridge & washing machine base $180
you sure you really need the above base? whatever for?
Dont need, then we'll do away with it.
Plumbing works
OK
Fibre Board & Plastering Works
this one quite fixed....
Agreed.
Painting Works
Supply & paint 1 layer Nippon Vinilex Oil base sealer whole unit $350
Supply & paint 2-3 coats (ICI/NIPPON) emulsion paint whole unit $1,250
Supply & paint whole unit door frame & piping in gloss paint $150
go for easywash paint - you wont regret.
Will asked for it.
Alum & Door Works
Fabricate & install 2 toilet adjustable lovure $400
Fabricate & install 2 top track alum bi-fold toilet door $520
Fabricate & install WPC alum casement window whole unit c/w blue tinted glass $2,600
Fabricate & install WPC alum grilles whole unit $900
Supply & install 4 pcs solid timber flush doors (Veneer) c/w lockset & stopper $1,400
Fabricate & install wrought iron main gate $420
casement windows are expensive, certain parts of the house can consider SLIDING instead.
We'll look into the windows with sliding options
Carpentry Works
Fabricate top & bottom 28ft laminate kitchen cabinet c/w ABC trimming,
handles,s/steel dish tray & 2 panel frosted glass $2,800
Supply & install 16ft solid surface kitchen worktop $1,280
Supply/Install 900mmX700mm s/stell backing $180
Fabricate/Install MBR 7ft FH laminate casement door wardrobe $1,400
Fabricate/Install bedroom 1 6ft FH laminate casement door wardrobe $1,200
Fabricate/supply bedroom 1 5ft laminate study table $700
Fabricate/supply bedoom 1 5ft mount cabinet $500
Supply/lay parquet flooring on 3 bedrooms $2,800
wow....i think it's the items that you want that costs so much...his price is quite standard leh.
Kitchen cabinet works out to be $100 per ft run. Is that on the high side?
All the wardrobes are essential, but is $200 per ft reasonable?
As for the parquet flooring, we'll get a 3rd party to do it.
Lastly, 4 pcs of Veneer doors cost $1,400? That's $350 each. Another ID quoted me $280 per door. Same product.
Thks again Mace.
Thks again Mace.
thats why i said you ask him for re-quote again when he is there in YOUR HOUSE.
certain things don wan, strike off, certain additional items to add...bla bla bla....
then finally ask him to reduce price.
I will try to ask him reduce the price :lol:
My quotation also same price as yours.
For door, other ID quote $280, is it come with c/w lockset & stopper?
Hi
Yap. It comes with the works. Is yours a 4 room unit?
Cheers
Please help comment on Ho Bee's quote. My place is a 4NG 92sqm flat in AMK.
General Works
Hack off existing kitchen & 2 toilets floor tiles $350
Hack off existing kitchen & 2 toilets wall tiles $700
Hack off existing living, dining & store floor tiles $480
Hack off existing 3 bedroom ceramic skirting $120
Discard existing kitchen cabinet & clear off site $180
Supply sand & haulage material to doorstep $650
Clear debris $150
Acid washing X 2 times $150
Masonary Works
Apply 3 layer waterproofing - kitchen & 2 toilet floors $300
Supply & lay kitchen ceramic/homo floor tiles $800
Supply & lay 2 toilets ceramic/homo floor tiles $800
Supply & install s/steel rubbish chute $180
Construct kitchen cabinet base $180
Supply & lay kitchen ceramic wall tiles till ceiling height $2,600
Supply & lay 2 toilets ceramic wall tiles till ceiling height $2,400
Patch up & make good 3 bedrooms skirting area $120
Supply & lay living, dining & store - 600mmX600mm homo floor tiles c/w skirting $2,200
Plumbing works
Rerun whole unit cold water copper piping $580
Labor fee to install sink in/outlet piping $120
Labor fee to install washing mach in/outlet piping $80
Labor fee to install 2 set instant water heater $120
Alter squatting to sitting sewage pipe line $150
Labor fee to install 2 set WC bowl $180
Labor fee to install 2 set wash basin $120
Labor fee to install 2 nos spray tap $60
Labor fee to install 2 set toilet accessories $60
Construct living/dining 9mm thickness fibre board ceiling $750
Plastering whole unit wall & ceiling $1,550
Painting Works
Alum & Door Works
Carpentry Works
TOTAL = $35,160 less discount $160
NETT PRICE = $35,000
Have not even include electrical works yet. Estimated $1,500.
Thks for everyone's feedback.
Hi vicenzo70
Is this yr 1st quotation ? Normally for first quotation he tends to charge accordingly until when he meet u couple of times, he may revise his quote.
My total reno also: 35K exclude electrical
U have alot to hack alot of things but its cheap compared to ID quote. :dunno:
I met up with Patrick to show him the unit yesterday night. He seem shy shy but very experience. One look can tell a lot of things
I understand that Ho Bee tile rates are up to $3 psf....if we ask for $2.5 psf do you think I can ask for a reduction of the quote?
Is Easywash paints cheaper or more ex the emulsion? Was thinking of the new light paints that suppose to brighten up the place more. Dont know if cost more
He charged avg abt $3 per tiles. Upon choosing tiles, he will calcualte n charge accordingly. Normally tiles difficult to ask to reduce bcos it doesn't make much difference.
Paint no difference regarding which u choose also.
If u want to reduce the quotation best is consider which item u would want to eliminate. My first quote is $40K. After sveral revise then final down to $35K :dunno:
Hi
Cheers
Yup, mine also 4 rooms 105sqm :dancingqueen:
If u want to reduce the quotation best is consider which item u would want to eliminate. My first quote is $40K. After sveral revise then final down to $35K :unsure:
Yup, $3 is just agar2 only.
After you choose the tiles then quote the real price.
For living room $3 and below only few choice, most are above $3.
If you want nicer tile for living room sure need to top up.
Only kitchen and toilet tiles are cheaper, most are around $2.2 - $2.6.
Edited by simeiz
yours start reno after CNY?
you wont regret on easywash...me already kena all sorts of dirts on the wall, bcos of easywash paint, sometimes water(damp cloth) alone can wipe the stains off liao - tougher one i just spray magicclean.
you need to top up some $ for easywash.
Edited by MaCe
Hi guys,
Was wondering, when asking Patrick to quote us the costs, do you chaps just call and tell him what needs to be done? Or do we need to come up with a detailed list like Vincenzo70? I hope it's not the latter coz I simply do not have the time! T_T
Also, as I had gotten a resale unit and had a verbal agreement with the seller that we can take the keys after the 1st appt, how does Patrick or any contractors can see the actual unit? Coz we had not took possession for now...
Edited by skywolf
Hi guys,
best is to plan what you want to do first. then get patrick to meet you in the house(i believe the current owners wont mind for just 30mins).
Hi Mace... =)
Together with FSM if i'm getting one to look over?
Btw, was wondering if Patrick whd mind if we happen to outsource certain part like windows to another party... Any idea? Was afraid he might mind even though i know we can do so...
definitely not. he will always ask you to go for the cheaper source
for my air-con, he actually told me that whatever he source he will charge $50 'admin fee' so better i go source myself
as long as you don't expect him to chase the contractor you engage can liao 8|
