Air-con Group Buy
Need quote on Inverter System 3 with 4 ticks for 3 room HDB.
Master Bedroom - 14.4M²
Common Bedroom - 13.5M²
Living Hall - 19.5M²
Can please recommend a suitable system 3? Preferable Daikin or Mitsubishi.
Thank you.
  • Replies 1.5k
  • Views 422k
  • Can add me too? Looking at mitsubishi electric or panasonic system 3 inverter aircon. Tks.
  • Hi I've engaged Tim n team for system 3 Toshiba. I'd say I'm very satisfied with the workmanship & service. It's very neatly done. The workers are friendly and basically, am very happy n satisfie
I need a quote on Inverter System 1 unit with 4 ticks for my living room hall.
It is about 150sqft.
Any recommendations? No preference in brand. Which brand is cheaper?
Hi Aron, I'm looking for a sys3 non-inverter unit since i seldom use the ac. Could you recommend and quote a few?
Some queries on aircon installation materials.
What's the difference of gas pipe gauge 22 & 23? And for the drainage pipe is it necessary to use 16mm instead of 13mm?
Armaflex Class O or 1 better? And for thickness 1/2" is it sufficient to prevent sweating or condensation?
We are now looking for a Mitsubishi StarMex system 4 inverter aircon for our 4rm HDB flat. May we know following?
1. Costs (air con units, dismantle and disposal of current aircon, installation, warrenty for 5 years etc)
2. Specifications (BTU, energy efficiency, cooling power etc)
3. Who is installing (e.g. Gain City)
Is this 4 ticks for energy efficiency?
Thanks!
I need 4 aircons. Dunno which brand to select yet..Do u pay home visit for quotation and advise mine 3in1 or 4in1 better as I need to put in living room. Tks...
hi Aron,
I'm looking for system 4, 1 for living hall & the other 3 for bedrooms. Please quote for both inverter & non-inverter. Thank you.
Hi Aron,
So do u mean G22 will be better since it is thicker than G23? Pls advise. Tks!
Hi Aron,
I'm looking to replace my aging Toshiba non-inverter system 3 (HDB, bedrooms only).
Can you please pass me your contact details and recommend a make/model that is easy to self-service?
I need something that will allow easy access and removal of the cross flow fan blade. The main/IR PCB, fan motor and rear housing should also be easy to disassmeble/replace for the fan coil to be fully exposed.
Hi Aron,
I'm looking for a System 3 Air-con. Can PM me the price of Panasonic System 3 Non-Inverter and all other brand you have?
Hi Aron,
My house is a new 4-rm HDB BTO flat (92 sqm). I am looking to install aircon for all 3 bedrooms as well as the living room. I will be having an open concept kitchen.
Kindly advise whether a system 4 (1 compressor) or a system 3 + single unit (2 compressors) is better. May I request for quotes for both inverter and non-inverter? Brand-wise, I have no preference, your recommendation is appreciated.
Thanks a lot.
hi aron,
im looking for aircon for my new 4rm flat. will be having an open concept kitchen so would appreciate if u could share ur views if i shuld get system3 + 1 or just system4. pls quote mi for inverter n non-inverter. do u do site quotation?
look forward to hear frm u
Just PMed you.
aron (aronputt@gmail.com)
Hi Aron, i'm interested to install a system 4 inverter aircon for my 4 rm.new flat.
What is the promotion for system 4 aircon?. Can i have diff prices like panasonic, mitsubishi,daikin and some other jap brands with a minimum of 3ticks?
does yr price includes all the installation works and parts as well?
Lastly, my flat shld be coming end of the yr to early 2012. do u still entertain?
thanks!
Aaron,
Would like to hear your views on the brands of different air con, which would you recommend for a system 2/3 in terms of their performance and durability.
I thinking of getting 3 x System 2 for my new place.
