Aircon Quotes (From Aron)
Hi Aron, I'm looking at system 3 (1x12000 BTU for MBR, 2x9000 BTU for 2 other bedrooms). Can give me a quote? And if we switch on the aircon is all 3 bedrooms, how many BTU for the compressor shld we consider? Thanks!
  • Replies 2.1k
  • Views 658.2k
  • I was told my a saleman selling aircon that the default grey insulation is good enuff if your aircon trunking is expose as most of the HDB are. And not hidden as those in the condominium. Armaflex ar
  • ok, there are retailers who try to cut corners to save $$. eg. they offer you system 3 at (est) $3.4k, generally the air-con mfgr specs will specify wat type of material to use, eg. for insulation, pi
  • i got a quote from gain city. Mitsubishi invertor, compressor is 30k btu, then 3X 9k units for 3 rooms, and a 22k unit for the living area. Cost is $3.4k. is it cheap? TO be honest, im a noob when it
hi aron...
looking to get aircon for my 3 room and 1 unit for living+dining...
3 rooms - 1 x 12k btu, 2 x 9k btu (inverter)
living+dining - 1 x 24k btu (non-inverter)
preferbly panasonic brand.. staying in condo so need conceal piping as well..
do PM me the cost also the estimate time of installation upon confirmation...
thx
Edited by evo55555
Hi..
I also need a quotation for air con system for 1 MBR + 2 rooms...
Sorry, what would you recommend?
Many thanks....
need advise
MHI system 3 scm60zm/srk25 x 3 (9000 Btu) @ $2735
Panasonic R410A CU-3S27MKZ/9MKZW/12MKZW (8154 x 2btu, 9314 x btu) @ $2775
Daikin - any reviews?
my room size:
MBR - 15.2m2
Room 1 - 14.10m2
Room 2 - 14.9m2
thanks folks
Hi Aron,
Need some quotes and recommendation on Inverter system 3 for a new 4 rm flet. 1 MBR + 2 bedrooms.
the aircon need to be quiet as had used before Sanyo very noisey.
thanks.
Hi Aron..
I need a quotation for an Inverter air con system for a system3 and a system4...
wanted to compare the prices 1st before i chose which one to go for...
my house is a 90m2 4rm HDB
thanks and regards ....
  • 3 weeks later...
Hi Aron,
I need the quotation as well for the system 3 inverter system for 4rm HDB. thanks.
Hi Aron,
I went down to Gain City and was recommended to purchase a System 3 Inverter from Sharp Model:
Indoor: AH-XPC9/12MV
Outdoor: AU-X3M24MV
The price is S$2,729.00, thus will like to know is the price reasonable?
Please Advise.
Anyone know where I can get good and reliable 2 nd hand aircon, I need it for my rental flat as the aircon(system2)... Went south on me and I need to fit it for the the tenant... Thanks...
Edited by noel
Hi All,
Do any of you hide your air con pipe inside the false ceiling?
Might be a bit late in the reply but I think this should benefit all users out there who have yet to install aircon. Please just leave the trunking visible. I know this is unsightly and definitely score lowly on WAF but it is the most practical thing to do. I did the opposite in my flat, going even to the extend of constructing plaster boards to conceal all trunking. Things were fine for the first couple of years. Then realize aircon lose its coolness too frequently. Servicing requires top up of gas once every year which suggests that there is a leak. However, difficult to do leak check due to the conceal pipes unless I'm willing to destroy the boards and then seal up again thereafter.
So my advise is to leave them out. Yes they will look ugly, but after a while, you'll learn to ignore them and will appreciate that they out out there should you ever need to check or service the piping.
Hi Aaron,
Possible to quote me Mitsubishi star mex inverter for 3 bedrooms?
Thanks
hi Aron, i am still waiting for your reply. i have pm u a few days ago. Tks alot.
I looking pansonic inverter, 3+1 any recomand ? Someone quote 2698 is reason ?
