The Cleaning Of Dirty Tiles And Grouts
I have one question to ask, i always travel for work and when i come home i notice my toilet floor is very dirty
and the grouts black, its seems very difficult to clean them, anyone expereinced this before? If yes what are the solutions to
remedy this?
Any help is appreciated :)
  • 5 weeks later...
  • Replies 39
  • Views 79.3k
  • CandiceChua
    CandiceChua
    Had the same mold and dirt/hard water stains problem same as TS, so i purchased the HCL89 thing from http://hcl89.byethost10.com as recommended I used it a couple of months back and so far the
  • BelindaSeah
    BelindaSeah
    There was some issue with tough stains on my tiles so decided to use the HCL89 from http://hcl89.byethost10.com and was able to remove the stain completely. Tried alot of stuff like vinegar and etc, b
  • Seems like it, but TS says he travels for work so should probably be months in between usage
remedy this?
Remedy - it's time to change floor tiles to darker color with rough surface and with minimum grouts. No white cement please.
Same strategy applies for the kitchen floor tiling.
  • 2 months later...
Rondell is this actually due to excess moisture?
Edited by TedDibiase
  • 1 month later...
Not too sure what causes this actually
  • 4 weeks later...
On 20/11/2014 at 2:25 AM, Rondell said:
If yes what are the solutions to remedy this?
From what you describe it seems to be ingrained dirt and hard water stains.
You can use something called HCL89. to clean the tiles
I usually get it from http://hcl89.byethost10.com or  http://hcl89.atwebpages.com
One thing i like about it is that is creates like a protection like on the tiles so that it prevents such hard water stains or dirt from becoming an issue for your tiles
Hope this helps you out :)
Edited by EricCantona
  • 1 month later...
I think maybe your tiles are dirty due to non usage, how long was period it was used in between?
anyone consider a jetspray ? admittedly, it's a bulky item to store.
but hey, no use of chemicals. And that's a good thing.
  • 3 weeks later...
Invest in a steam vacuum cleaner. Can be use to steam your tiles grout, sofa, mattress and even curtain to save on dry cleaning cost.
  • 1 month later...
Jetspray i think uses alot of water, your water bill will skyrocket, not advisable in my opinion
  • 5 months later...
Hi all,
May i check with gurus here, what should i use to fill grouts? Toilet floor tiles are grouts are exposing...dun know what to use to refill them especially its for toilet floor...
Thanks in advance for advice.
  • 2 months later...
Edited by Glenn72
  • 2 months later...
Ya water bill will go through the roof
  • 3 weeks later...
Wht's causing it to be so dirty?? Even I think changing the floor tiles with a darker color might be helpful..
  • 1 month later...
Actually to avoid excessive moisture in the toilet, is it possible to just cover the air vent in the toilet?
