Ceiling Fan
There r 2 types of remote controllers. :)
1) using Infra Red. (IR) method
2) using Radio Frequency (RF) method
In order for a remote to work, u need a reciever and a transmitter.
The reciever will be connected to the fan and place on the fan and the transmitter will be the controller that you press to select yr setting.
Usually, for fan using (IR) method, the remote circuitry will be built into the fan circuitry.
whereas for fan using (RF) method, the remote circuitry need not be built into the fan circuitry.
Hope this helps. ;)
Cheers pal :drunk:
yes it did, thank you very much! :)
  • Replies 951
  • Views 324k
Hey Bro,
Can you share your lobang contacts with me as well?
Thanks.
silverbacks
Looking for 2 fans :D
Hi Bro, can PM me your lobang? Much Thanks.
Another question: Noticed that KDK fan do not have light fitted on... Is there any plc that sell KDK fan with light fittings? Thanks..
Hi pal,
Hv Pmed u liao... :notti: hope you'll save abit n buy me kopi ya :dribble: :dribble:
Cheers pal :drunk:
Hi Bro!
Can you PM me your contacts as well. Thanks!
Cheers!
Hi sinhome,
Cheers pal :drunk:
Hi Bro, may have the KDK ceiling fan lobang? thanks
Hi xterzoo,
I dun hv any kdk lobang only FANCO lobang. :(
Cheers pal :drunk:
Thanks Bro :D
Thanks bro for installing the fanco aroma fan.. Good workmanship!
Now i don't need the stand fans. And its cooler now. Thanks again.
I'm interested in getting the KDK V60WK model for my living room and master bedroom.
Because my ceiling is pretty high (non-HDB) even with false ceiling, I probably need an extension rod.
1) Do V60WK come with extension rod?
2) If not which other model or brand is similar in construction (simple+no lights+powerful+remote)?
Thanks!
U're most welcome, glad that u enjoyed the breeze... :lol:
Cheers pal :drunk:
Boss, can u pm me the lobang too??
Hi Bro - Can you please share your Fanco lobang? Tks!!
Hi, dun think kdk remote models fans can extend the rod. Unless u're taking the 3 blades regulator type.
U can always scout around 2 c if there r any design that u're like.
Remote control is juz an add on to the fan for other make.
Hope this helps;)
Cheers pal :drunk:
Hi Bro, thanks for your prompt reply.
I was looking around the Fanco website and have a few questions which i hope u can help with:
1) Can u recommend Fanco's most powerful models with simple lines, no light attachments and I don't like the chain hanging down some of the models?
2) Can the speed regulator be substituted with aftermarket switch plate makers' such as Legrand/MK since I am trying to unify the switches throughout the house?
3) all the Fanco models can be adjusted for height?
4) is it better to attach the base to the false ceiling via bracket or directly to the concrete ceiling and passing through the false ceiling?
5) can PM me the prices of the models u recommended as I am getting 3 sets for my new place.
Thanks!
Hi Bro,
Pls pm me the contact for Franco fan too. Need to buy at least 9 Fans, the savings will definitely helps!
Thanks!
